I understand that the arduino uno wifi was an arduino.org product, but the two companies have combined now so i assume i can ask for help here.
I remember a couple of months ago i fixed my problem by getting the arduino.org IDE but now there is only one IDE to get from arduino.cc. It says online that the newest IDE supports all boards including the arduino uno wifi. Does it support the WIFI Link library for the arduino uno wifi too? if not what library can i use to do UDP messaging? currently on the arduino 1.8.5 IDE i get this error when i try to compile the WiFiUdpNtpClient example in the wifi link library :
In file included from /home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp:30:0:
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp: In member function 'void WfSerial::begin()':
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.h:38:16: error: 'SerialWiFi' was not declared in this scope
#define Serial SerialWiFi
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp:38:3: note: in expansion of macro 'Serial'
Serial.begin(ESP_CH_UART_BR);
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp: In member function 'int WfSerial::read()':
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp:44:7: note: in expansion of macro 'Serial'
c = Serial.read();
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp: In member function 'void WfSerial::write(unsigned char)':
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp:54:3: note: in expansion of macro 'Serial'
Serial.write(c);
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp: In member function 'int WfSerial::available()':
/home/liam/Arduino/libraries/WiFi_Link/src/utility/uart/serial.cpp:60:9: note: in expansion of macro 'Serial'
num = Serial.available();
exit status 1
Error compiling for board Arduino Uno WiFi.\
Please Let me know if there is anything i can do, so i can still use these boards. Thanks
