Arduino Uno Wire library freezes - Try to solve it
Hi everybody,
I've tried to find a solution to freezing situations of the Arduino Uno Wire Library.
For details, the functions twi_writeTo and twi_readFrom contain some while loop and it can be impossible to exit without a reset.
Attached is my solution to solve these problems.
The file wire.c must be replaced by the new one in folder C:\arduino-1.0.6\libraries\Wire\utility (adapt the path).
twi.c (17.8 KB)
jmparatte: I just came across this posting linked from some others. I have spent hours trying to figure out a solution to my Wire.endTransmission() and reading the posts from others (all helpful but no solution worked so far). I have 2 Unos on a I2C: the sender hangs when the other Uno is unplugged. I am new to programming and Arduino: If I learn "C" will I then be able to understand the workings of twi.c? Thank you for the advice in advance: I will try your twi.c now.
I am running Arduino 1.8x and I have 2 Uno R3 connected via I2C. I just replaced the stock twi.c with yours (exact same file name, exact same location) and this is the error I got trying to compile. I apologize but I do not know anything beyond Arduino interms of programming so the compile error as well as the twi.c file is Greek to me :frowning:
Thank you for any and all help!
libraries\Wire\utility\twi.c.o (symbol from plugin): In function `twi_readFrom':
(.text+0x0): multiple definition of `twi_readFrom'
libraries\Wire\utility\STOCK ARDUINO LIB twi.c.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `twi_writeTo'
(.text+0x0): multiple definition of `twi_transmit'
(.text+0x0): multiple definition of `twi_init'
(.text+0x0): multiple definition of `twi_setAddress'
(.text+0x0): multiple definition of `twi_attachSlaveRxEvent'
(.text+0x0): multiple definition of `twi_attachSlaveTxEvent'
(.text+0x0): multiple definition of `twi_reply'
(.text+0x0): multiple definition of `twi_stop'
(.text+0x0): multiple definition of `twi_releaseBus'
SamBrownADK:
Hi SamBrownADK,
TWI is probably one of the most complex peripheral of UNO. I continue to work on Wire Library and its dependences (twi.h, twi.c) but I'm not ready to publish a common alternative to Wire.h because there are lot of I2C cases. For example, I've written a new LiquidCrystal_I2C without any kinds of delay (LiquidCrystral delays and Wire delays).
I've never checked the case of I2C communication between to Arduino. I prefer to use a Serial port.
OK, thanks. I just googled the serial port to try to see how to use that as well... maybe that is my best route.. Thank you again!
