Arduino uno with 10m led string
Hello!
I'm new in the arduino world, at first I was wondering what is the maximum amperage that my arduino uno can resist if nothing is connected on pins
I want to control a 10meters led string rgb, which works with 6ampers and 9volts, can i do it directly or should i use a transistor?
Thanks to all
hernancar2o:
No.
You should use external power supply which can handle 6 Ampere and Power MOSFET or Transistor with Arduino's PIN.
9V is rather odd for an LED strip, is this some hacked xmas-tree lights? 12V is
more common for strips and easier to find a power supply for (in the 6A range).
There are examples of how to control high current loads in the playground I believe.
