You will have to tell us the EXACT frequency and the modulation method and the data coding method of the TMPS you want to monitor. Only then can you pick a 433mHz receiver to receive only that data from the TMPS.
Right now I dont know which type of TPMS sensor use the modulation method as their is no description.
for your reference I will share the the TPMS sensor
Ok, But I failed to see where you got the idea that they operate on the 433-433.9 mHz band. Why do you want to use a different receiver from the one offered?
I am not sure if the sensor will operate on this band or not. Thats why I requested for guidance and suggestions.
I found this documents realted to modulation method. 7- TPMS Protocol US patent.pdf (796.5 KB)
My idea is to captured the data from the TPMS sensor wirelessly and transfer this data into PLC and made some programe and control the machine with this data. if there is pressure low in the rotating shaft then it will show results or generate alarm.
I already done this with TPMS BLE sensor using HM-10 shield but that is not good enough for transmitting the data, so thats why i want to use this type of sensor which transmit data through radio frequency.
If you know any solution or reommend me any other hardware to do this.
DSD Tech makes a variety of Bluetooth and BLE modules. They are of good quality and there is technical support available from the company. Perhaps there is a ble module with better transmission characteristics.
Can you have the HM10 with external antenna ? or similar type of BLE modules which has same working principle like HM-10 and has external antenna ? because i want to use in industrial environment .
I think the tuned antennas integrated with the bluetooth modules will give better performance than an untuned diy replacement, but I have no direct experience with using external antennas on bluetooth or ble modules
Are you are having range issues with the BLE solution which is currently working and that is motivating the change to 433 MHz?
Yes, when I enclosed the HM-10 in a box then it effect the signal ranges and also the response time.
This is why I wanted to work with radio frequency modules.
Thanks for sharing the infomration and website for BLE modules.
