I am trying to make an Arduino logger with a phpMyAdmin server, but after it runs 4 HTTP GET requests the Arduino says that there is an error "No Socket Available".
Can anyone please send me a solution for this error?
Many Thanks.
Many Thanks.
phpMyAdmin is a script that presents a user interface on a browser that allows the user to manipulate MySQL databases.
It will NOT be the basis of your Arduino logger.
Once you accept a client connection, you must properly handle the client request AND close the socket. If you don't, the socket remains in use. There are only 4 sockets available.
Thanks for the reply,
This is my Request:
if (client.connect(server, 80)) {
i+=1;
client.println("GET /write_data.php?hue=1000&tmp=999.9&ID=001");
Serial.print("\nconnecting");
client.println(); // Empty line
if (client.available() && status == WL_CONNECTED) {
char c = client.read();
Serial.write(c);
client.flush();
client.stop();
can you please review?
Many Thanks.
Serial.write(c);
client.flush();
client.stop();
If the server generated a response, and that response arrived within nanoseconds, read ONE character, and then shut down the client. That is NOT how to deal with the server response.
while(client.connected())
while(client.available() > 0)
Serial.print(c);
Once you have read the complete server response, the connection will be closed automatically, and the socket closed.
So it needs to look like this?
Serial.print(c);
This whole code is inside of the loop void do I need to move some of it to the setup void?
GuyYanai:
Tell me what you would call this:
int analogRead(int whichPin)
int val = 0;
// Do something
return val;
It is NOT an int.
Your code doesn't have any voids, either.
It has FUNCTIONS.
All the code in the snippet goes in the loop() function.
