I have my Bluetooth 2.0 HC-06 plugged into the pin 0(RX) and 1(TX). When I try to run a sketch I get this error: avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x11 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x11 I know it is the plugins to these pins because once I take them out, everything runs fine. Why are those pins not working?
(deleted)
I am running this code and typing AT command but my bluetooth 2.0 isn't responding back. This is my sketch
include
SoftwareSerial mySerial(5, 6); // RX, TX
Serial.begin(57600);
//pinMode(9,OUTPUT); digitalWrite(9,HIGH);
Serial.println("Enter AT commands:");
mySerial.begin(57600);
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
Wrong pins, wrong baud rate, wrong code, and probably wrong anything else - including, most certainly, the wrong instructions. The first thing to consider is: do you really need to do this anyway?
You might find the following background notes useful.
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
But when I use the Rx->TX and TX->RX I cannot run arduino sketches I get the error I described above.
So, the background notes I provided a link to were of no use to you after all?
