Not sure if it is the program or if it is the router but I can not get the arduino uno with ethernet shield to send data to another pc wirelessly.
Can you view the program and tell me if there is anything that will help it work better. time is running out and I need to finish this before next week. please help Michael Albert
Here is the code> Thank you.
- The purpose of this program is too monitor the voltage of a battery and depending on the voltage generator.
- The controller needs to handle a wide voltage range and a wide current range if connected to a turbine
- of varying speed. The speed can vary greatly and therefore the out will have to be carefully monitored.
- The controller will have the following states:
- Battery voltage below 14.0v : charge the battery
- Battery voltage 14.0v or above : dump the turbine generator power to a dummy load
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
byte mac[] = { 0x90, 0xA2, 0XDA, 0X0D, 0X8B, 0X11 }; //mac address for Arduino//
byte ip[] = { 192, 168, 3, 178 }; //ip address//
byte gateway[] = { 192, 168, 1, 1 }; //internet access via router//
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(23); // server port
// Voltage divider constants (ohms)
const int VD_R3 = 10000;
const int VD_R4 = 1000;
// Manual buttons
const int CHARGE_BUTTON = 2; // DIN
const int DUMP_BUTTON = 3; // DIN
// LED displays
const int STATUS_LED = 13; // DOUT
// Battery charging
const int BATTERY_MONITOR_PIN = 0; // AIN
const int INSTRUCTION_PIN = 6; // DOUT
const float BAT_VMIN = 11.9;
const float BAT_VMAX = 14.0;
// Turbine RPM monitoring
const int RPM_MONITOR_PIN = 1; // AIN
// Other
const int DELAY_TIME = 32; // 32 default
// Program variables
bool manual = false;
bool charging = false;
EthernetClient client;
pinMode(STATUS_LED, OUTPUT);
pinMode(CHARGE_BUTTON, INPUT);
pinMode(DUMP_BUTTON, INPUT);
pinMode(INSTRUCTION_PIN, OUTPUT);
digitalWrite(STATUS_LED, HIGH);
if (Ethernet.begin(mac) == 0){
Serial.println("Failed to configure Ethernet using DHCP");
for(;
Serial.println(Ethernet.localIP());
int vin = analogRead(BATTERY_MONITOR_PIN);
float voltage = calculateBatteryVoltage(vin);
int rin = analogRead(RPM_MONITOR_PIN);
int rpm = calculateRPM(rin);
if (chargeButtonDown())
manual = true;
charge();
else if (dumpButtonDown())
manual = true;
dump();
if (!manual)
if (voltage < BAT_VMAX)
charge();
dump();
manual = false;
delay(DELAY_TIME);
float calculateBatteryVoltage(int vin)
float resconst;
if (VD_R3 == 0 || VD_R4 == 0)
resconst = 1.0;
resconst = ((VD_R3 + VD_R4) / VD_R4);
return (5.0 / 1023.0) * resconst * vin;
int calculateRPM(int rin)
// this function will determine the rpm from an analog value
// for now just return value passed
return rin;
inline bool chargeButtonDown() { return (digitalRead(CHARGE_BUTTON) == HIGH) ? true : false; }
inline bool dumpButtonDown() { return (digitalRead(DUMP_BUTTON) == HIGH) ? true : false; }
inline void charge() { digitalWrite(INSTRUCTION_PIN, HIGH); charging = true; }
inline void dump() { digitalWrite(INSTRUCTION_PIN, LOW); charging = false; }
inline bool getState() { return (charging) ? true : false; }
void SerialWriteData(float voltage, int rpm)
Serial.print("Voltage: ");
Serial.print(voltage);
Serial.print("V");
Serial.print("RPM: ");
Serial.print(rpm);
// TO DO: show whether charging or not
Also can not find a proper arduino ip address maybe that is the problem again help and thanks
