arduino uno with icomsat error DB :NO RESP
hello i have arduino uno r3 and icomsat v1.1 . i connect the uno with usb, not use external power. here the code
#include "SIM900.h"
#include <SoftwareSerial.h>
//If not used, is better to exclude the HTTP library,
//for RAM saving.
//If your sketch reboots itself proprably you have finished,
//your memory available.
//#include "inetGSM.h"
//If you want to use the Arduino functions to manage SMS, uncomment the lines below.
#include "sms.h"
SMSGSM sms;
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to send and receive SMS.
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
     //Serial connection.
     Serial.println("GSM Shield testing.");
     //Start configuration of shield with baudrate.
     //For http uses is raccomanded to use 4800 or slower.
     if (gsm.begin(2400)) {
          Serial.println("\nstatus=READY");
          started=true;
     } else Serial.println("\nstatus=IDLE");
    // if(started) {
          //Enable this two lines if you want to send an SMS.
     if(started) {
       sms.SendSMS("3471234567", "Arduino SMS");
          Serial.println("\nSMS sent OK");
          //Read if there are messages on SIM card and print them.
        /**  deprecated method
        if(gsm.readSMS(smsbuffer, 160, n, 20)) {
               Serial.println(n);
               Serial.println(smsbuffer);
          //get 1st sms
       //   sms.GetSMS(1,n,20,smsbuffer,160);
        //  Serial.println(n);
        //  Serial.println(smsbuffer);
i use tx 6 and rx 7, i change the library GSM.cpp to tx 6and rx7, but on the serial monitor it show DB:NO RESP , i change the baudrate it still not working.
