Arduino Uno with LN298 // Uno with TB6612
Hello
In my Programm i do work with two DC Motors 6V, regulatet by two potentiometer .
The motors can by regulatet by for-and backward.
With the Arduino by LN298 this is working without Problems. :slight_smile:
Current by 6,24V
Now i wanted run that programm with the Arduino Uno and the TB6612.
But this not works. >:(
What y have donne wrong? :frowning:
In future i want run this Programm by using the Seeduino Xiao by the TB6612. Is this possible? :sunglasses:
Thanks for your return.
Regards
Reka5
Without being there there is no way I can help. If you post a schematic, not a frizzy drawing showing all power, ground, interconnections and power sources along with links to each hardware item.
I think this tutorial will help you to get on you way.
Power supply voltage: VM = 15 V(Max)
Output current: IOUT = 1.2 A(ave)/3.2 A (peak)
Post a wiring diagram and your present code.
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
OR
https://forum.arduino.cc/index.php?topic=712198.0
Then look down to "code problems" about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Can you please post a copy of both your circuits, in CAD or a picture of a hand drawn circuit in jpg, png?
The 298 circuit and the TB6612 ciruit.
Please include power supplies and pin/terminal names.
Please not a Fritzy picture.
Thanks... Tom.. :slight_smile:
