Arduino UNO with RFID MFRC522 Connecting with XAMPP Localhost.
Hi guys I’m new here in arduino. I am trying to display the data that I’ve received in Arduino to XAMPP localhost database. The connection is okay, but the PHP connection got a problem. What seems to be the problem here ? I’m guessing that the problem is the PHP file
Here’s the code of Arduino:
 #include<SPI.h>
#include<MFRC522.h>
#include<SoftwareSerial.h>
#include <Ethernet.h>
#define SS_PIN 4 //FOR RFID SS PIN BECASUSE WE ARE USING BOTH ETHERNET SHIELD AND RS-522
#define RST_PIN 9
#define No_Of_Card 3
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "192.168.254.102";   //YOUR SERVER
IPAddress ip(192, 168, 254, 106);
EthernetClient client;
SoftwareSerial mySerial(8,9);
MFRC522 rfid(SS_PIN,RST_PIN);
MFRC522::MIFARE_Key key;
byte id[No_Of_Card][4]={
  {53,69,32,119},             //RFID NO-1
  {112,224,72,84},             //RFID NO-2
  {151,94,80,84}              //RFID NO-3
byte id_temp[3][3];
byte i;
int j=0;
  mySerial.begin(9600);
  SPI.begin();
  rfid.PCD_Init();
  for(byte i=0;i<6;i++)
    key.keyByte[i]=0xFF;
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    Ethernet.begin(mac, ip);
  Serial.println("connecting...");
{int m=0;
  if(!rfid.PICC_IsNewCardPresent())
  return;
  if(!rfid.PICC_ReadCardSerial())
  return;
  for(i=0;i<4;i++)
   id_temp[0][i]=rfid.uid.uidByte[i];
             delay(50);
   for(i=0;i<No_Of_Card;i++)
          if(id[i][0]==id_temp[0][0])
            if(id[i][1]==id_temp[0][1])
              if(id[i][2]==id_temp[0][2])
                if(id[i][3]==id_temp[0][3])
                  Serial.print("your card no :");
                  for(int s=0;s<4;s++)
                    Serial.print(rfid.uid.uidByte[s]);
                    Serial.print(" ");
                  Serial.println("\nVALID");
                  Sending_To_DB();
                  j=0;
                            rfid.PICC_HaltA(); rfid.PCD_StopCrypto1();   return;
   {j++;
    if(j==No_Of_Card)
      Serial.println("inVALID");
      Sending_To_DB();
      j=0;
     // Halt PICC
  rfid.PICC_HaltA();
  // Stop encryption on PCD
 void Sending_To_DB()   //CONNECTING WITH MYSQL
   if (client.connect(server, 80)) {
    Serial.println("connected");
    // Make a HTTP request:
    client.print("GET /rfid/MASTER_CODE/ethernet.php?id='22'");     //YOUR URL
//    if(j!=No_Of_Card)
//      client.print('1');
//    else
//      client.print('0');
                    client.print(rfid.uid.uidByte[s]);
    client.print(" ");      //SPACE BEFORE HTTP/1.1
    client.print("HTTP/1.1");
    client.println();
    client.println("HOST: 192.168.254.102");
    client.println("Connection: close");
    client.println();
    // if you didn't get a connection to the server:
    Serial.println("connection failed");
  client.stop();
I don’t receive error from my arduino code.
Here’s my PHP connection code:
<?php
class rfid{
 public $link='';
 function __construct($id){
  $this->connect();
  $this->storeInDB($id);
 function connect(){
  $this->link = mysql_connect('localhost','root','') or die('Cannot connect to the DB');
  mysql_select_db('rfid') or die('Cannot select the DB');
 function storeInDB($id){
  $query = "insert into tb_rfid set rfid='".$id."'";
  $result = mysql_query($query) or die('Errant query:  '.$query);
Sorry for my ignorance.
If you knew what localhost meant, you’d know that that is not going to happen.
#include<SPI.h>
#include<MFRC522.h>
Why dosome lines havespaces while othersdonot?
#define RST_PIN 9
You’re doing software serial on the reset pin for the RFID reader? Bizarre. Does that actually work?
{int m=0;
NOTHING follows the { on the same line!
  for(i=0;i<4;i++)
             delay(50);
Why
on
earth
do
you
delay
between
copying
each
byte?
Ever heard of memcmp()? Of for loops?
//    else
    client.println();
Add Serial.print() statements to print the exact same data. Show us what you get. Do you think that those statements will do what you expect? I don’t.
Look at a typical URL. Following the ? are name=value pairs, separated by commas.
Does your code produce data like that?
karlandrewleonor:
 #include<SPI.h>
#include<MFRC522.h>
#define RST_PIN 9
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server = “192.168.254.102”;  //YOUR SERVER
byte id_temp[3][3];
byte i;
int j=0;
  SPI.begin();
  rfid.PCD_Init();
    Serial.println(“Failed to configure Ethernet using DHCP”);
  Serial.println(“connecting…”);
{int m=0;
  return;
  return;
  for(i=0;i<4;i++)
            delay(50);
                  Serial.print(“your card no :”);
                    Serial.print(" “);
                  Serial.println(”\nVALID");
                  Sending_To_DB();
                  j=0;
  {j++;
    if(j==No_Of_Card)
      Serial.println(“inVALID”);
      Sending_To_DB();
      j=0;
    // Halt PICC
  rfid.PICC_HaltA();
    Serial.println(“connected”);
    client.print(“GET /rfid/MASTER_CODE/ethernet.php?id=‘22’”);    //YOUR URL
//      client.print(‘1’);
//    else
//      client.print(‘0’);
    client.print(“HTTP/1.1”);
    client.println();
    client.println(“HOST: 192.168.254.102”);
    client.println(“Connection: close”);
    client.println();
    // if you didn’t get a connection to the server:
    Serial.println(“connection failed”);
  client.stop();
I don't receive error from my arduino code.
Here's my PHP connection code:
<?php
class rfid{
public $link=’’;
  $this->connect();
function connect(){
  $this->link = mysql_connect(‘localhost’,‘root’,’’) or die(‘Cannot connect to the DB’);
  mysql_select_db(‘rfid’) or die(‘Cannot select the DB’);
  $query = “insert into tb_rfid set rfid=’”.$id."’";
‘’‘mysql_connect’’’
the above statement is obsolete and its no longer use by PHP… but you can use ‘‘mysqli_connect’’ instead
