I have a SharpGP2D12 connected to my arduino uno via analog in 1. I tested the range sensor with my multimeter and am getting the correct values. When I run my code however, I get really weird values. I wrote this code to try and convert the values into centimeters. I put the code and the output below, if anyone has any ideas I would greatly appreciate it, not sure why the values are incorrect.
It actually worked earlier and I think I might have messed up the code somehow and I have gone too far to undo it... I have no idea what is going on now. Some of the stuff below is code also for another function just look at the range stuff.
//function prototypes
void readrange(); // range sensor
//void accel(); // accelerometer
const int xPin = 9;
const int yPin = 10;
int analogInPin = A1;
pinMode(analogInPin,INPUT);
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
void loop() { // call functions
readrange();
//accel();
void readrange(){
float sensorValue; // value of sensor
int tmp; // temporary variable for storing value
tmp = analogRead(analogInPin);
if(tmp < 3){
Serial.println("incorrect value");
sensorValue = (6787.0 /((float)tmp - 3.0)) - 4.0;
Serial.println(sensorValue);
delay(300); // delay so it is readable
output while having the sensor looking at something sitting still about 10 cm away;
124.06
31.35
2.65
incorrect value
-2266.33
2.65
2.99
incorrect value
-2266.33
2.65
66.70
incorrect value
-2266.33
4.42
incorrect value
-2266.33
2.65
incorrect value
-2266.33
2.65
etc...
