Arduino UNO with SM5100B
Hello !!!
I m using Arduino UNO with GSM module SM5100B . The Problem i m facing is that, when i download the program in UNO. The GSM module sends sms perfectly. but when i disconnect the USB cable from Arduino, and then plug in the USB Cable again, it doesnot send the SMS. The program does not run.
I checked the UNO with out the SM5100B. I download some program in it. It executes the program, then i remove the USB Cable and plugg in the USB cable again. The program executes perfectly.
Do you refer me some guidelines in this regards.
Also i want to know that, can I connect the external power source (+5v) to the UNO with SM5100B during the downloading of program in it.
Regards,
Zee Alam
i just want to send SMS from it.
Can you post your code?
okie
/* Example 26.4 Send a text message upon an event occurring
http://tronixstuff.com/tutorials > chapter 26 */
#include <NewSoftSerial.h>
NewSoftSerial cell(2,3); // We need to create a serial port on D2/D3 to talk to the GSM module
char mobilenumber=“03455900675”; // Replace xxxxxxxx with the recipient’s mobile number
char textmessage[160]; // used to hold contents of message to send
int b=0;
{ //Initialize serial ports for communication.
cell.begin(9600);
delay(35000); // give the GSM module time to initialise, locate network etc.
// this delay time varies. Use example 26.1 sketch to measure the amount
// of time from board reset to SIND: 4, then add five seconds just in case
pinMode(13, OUTPUT); // use the LED for status
randomSeed(analogRead(0));
void startSMS()
// function to send a text message
digitalWrite(13, HIGH);
cell.println(“AT+CMGF=1”); // set SMS mode to text
cell.print(“AT+CMGS=”);
cell.print(34,BYTE); // ASCII equivalent of "
cell.print(mobilenumber);
cell.println(34,BYTE); // ASCII equivalent of "
delay(500); // give the module some thinking time
void endSMS()
cell.println(26,BYTE); // ASCII equivalent of Ctrl-Z
delay(15000); // the SMS module needs time to return to OK status
digitalWrite(13, LOW);
startSMS();
cell.print("The random number is: ");
cell.print(b);
endSMS();
b++;
delay(2000)
How much time are you waiting between unplugging it and plugging it back in?
1 minute
Need help !!! Please Reply :(
Sorry can't really think of a reason why it wouldn't work after unplugging it then plugging it back in with that code.
When you unplug and replug the port changes -are you taking that into account?
