Arduino uno with W5100 shield isn't starting up correctly
I made an udp sender and receiving. It al works, only while installing it. I saw that when i connect power supply to power, the Arduino with the shield doesn't boot properly. And doesn't start sending or receiving udp packet. When the power supply is connected and i plug it in the arduino or press the reset button everything works fine. Any thoughts how i can fix this?
i'm using an arduino uno rev 3
W5100 ethernet shield
Maybe a solution is giving an reset command. I implemented this in my code, only didn't found a valid way of when using the reset command. Any thoughts of that?
codo:
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <SoftwareSerial.h>
// netwerk instellingen
byte mac [] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
IPAddress exip(10,0,0,89);                // externe ipadress
IPAddress myip(10,0,0,90);
IPAddress gatewayIP();
unsigned int localPort = 8888;            // local port to listen on
// udp configuratie
EthernetUDP Udp;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE]; //buffer to hold incoming packet
int packetSize; // Packet grootte
int packetdata; // Waarde
const int tringPin =9;   // Bel, aansuitpin
int tringState = 0;
byte tringloop = 0;
// timers gegevens
unsigned long previoustimetring = 0;
unsigned long previoustimecycles = 0;
const long intervaltring = 150;
const long intervalcycles = 3000;
unsigned long currenttimecycles;
unsigned long currenttimetring;
//Reset function
void(* resetFunc) (void) = 0;
pinMode(tringPin,OUTPUT);
// internet opstarten
Ethernet.begin(mac, myip);
Udp.begin(localPort);
  //hardwarestatus check
   if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.");
  else if (Ethernet.hardwareStatus() == EthernetW5100) {
    Serial.println("W5100 Ethernet controller detected.");
  else if (Ethernet.hardwareStatus() == EthernetW5200) {
    Serial.println("W5200 Ethernet controller detected.");
  else if (Ethernet.hardwareStatus() == EthernetW5500) {
    Serial.println("W5500 Ethernet controller detected.");
  Serial.println(Ethernet.gatewayIP());
// timers starten
unsigned long currenttimetring = millis();
unsigned long currenttimecycles = millis();
// if there's data available, read a packet
 packetSize = Udp.parsePacket();
    if(packetSize) {
      if (Udp.remoteIP() == exip)
          Serial.print("Received packet of size ");
          Serial.println(packetSize);
           Serial.print("Remote IP: ");                     // bericht vanuit welk ip
           Serial.println(Udp.remoteIP());
           Serial.print("remote port is ");                 // bericht vanuit welke poort
           Serial.println(Udp.remotePort());
           Udp.read(packetBuffer,UDP_TX_PACKET_MAX_SIZE);   //read the packet into packetBuffer
           packetdata= atoi(packetBuffer);    // van char (packetBuffer) een int (packetdata) maken
           Serial.print("Packetbuffer: ");                      // inhoud packetBuffer
           Serial.println(packetBuffer);
           Serial.print("packetdata: ");                 // inhoud packetdata
           Serial.println(packetdata);
           Serial.print("tringloop: ");
           Serial.println(tringloop);
   if (packetdata == 1)   {
      (tringloop = 1);
      previoustimecycles = currenttimecycles;
      else if (currenttimecycles - previoustimecycles >= intervalcycles)
           { (tringloop = 0);
    if (tringloop == 1) {
     if (currenttimetring - previoustimetring >= intervaltring)    {
        previoustimetring = currenttimetring;
          if (tringState == 0)
              {   (tringState = 1);    }
              {   (tringState = 0);   }
    if (tringloop == 0)
  digitalWrite(tringPin, tringState);
  memset(packetBuffer, 0 ,UDP_TX_PACKET_MAX_SIZE);
Both of these functions return values. It is not a good idea to ignore them, and assume that they worked.
Anonymous printing sucks. Printing a value that never changes, on every pass through loop(), is pointless.
           { (tringloop = 0);
(What) (are) (the) (parentheses) (for) (?)
Or
    tringState = !tringState;
PaulS:
{ (tringloop = 0);
Or
Both these values are hard programmed, I use an static ip and my mac addres won't change. And the port where udp will communicate over is also static.
I was trying some things, so that's why i used this code. And i do know that it is useless. Only i saw that the gateway adress that is printed isn't correct. it says the 10.0.0.1 while this isn't the gateway adress according to ipconfig, and the login page of the router.
(tringloop = 0);
this variable is used for the action that will happen after i receive an udp packet with certain data. For example an 0 or 1. if it is an 1 an function will be run.
