Arduino Uno + Yun Shield
Hey guys! Kind of new to the Arduino. I have worked on the problem now for over a week, searching, testing without solution.
My project:
  • Arduino Uno w Yun Shield Ethernet and a DH22 2302 Digital Temperature Humidity Sensor
Task:
  • At a set ms parameter the temp and humdity is read and sent as a string to a mysql database over the ethernet.
Goals so far:
  • Webserver up and running, accepts strings over the .php file (included)
  • When just connecting the sensor to the Arduino and using code just for that, sensor values are reported.
  • Yun shield is detected from the router, and i can enter the webadmin of it
Problems:
  • When i upload my sensor and string poster on JUST the Arduino Uno it correctly uploads. But when i have the Yun Shield attached (and the sensor) i get the sync error:
System wide configuration file is “C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf”
Using Port : COM9
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd8
Facts:
  • Arduino is detected by windows, at com9, i have set the baud rate to 115200 via the device manager.
  • Arduino is found in the Arduino 1.6.5 on its correct comport
Code:
#include <DHT.h>
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x01 }; // RESERVED MAC ADDRESS
EthernetClient client;
#define DHTPIN 2 // SENSOR PIN
#define DHTTYPE DHT11 // SENSOR TYPE - THE ADAFRUIT LIBRARY OFFERS SUPPORT FOR MORE MODELS
DHT dht(DHTPIN, DHTTYPE);
long previousMillis = 0;
unsigned long currentMillis = 0;
long interval = 250000; // READING INTERVAL
int t = 0;  // TEMPERATURE VAR
int h = 0;  // HUMIDITY VAR
String data;
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
  dht.begin();
  delay(10000); // GIVE THE SENSOR SOME TIME TO START
  h = (int) dht.readHumidity();
  t = (int) dht.readTemperature();
  data = "";
void loop(){
  currentMillis = millis();
  if(currentMillis - previousMillis > interval) { // READ ONLY ONCE PER INTERVAL
data = "temp1=";
data.concat(t);
data.concat("&hum1=");
data.concat(h);
  if (client.connect("www.na.com/fangst",80)) { // REPLACE WITH YOUR SERVER ADDRESS
    client.println("POST /add.php HTTP/1.1");
    client.println("Host: na.com/fangst"); // SERVER ADDRESS HERE TO
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.print("Content-Length: ");
    client.println(data.length());
    client.println();
    client.print(data);
  if (client.connected()) {
    client.stop();  // DISCONNECT FROM THE SERVER
  delay(300000); // WAIT FIVE MINUTES BEFORE SENDING AGAIN
Error result:
Pastebin - Upload results with the Arduino/ Genuino Uno selected in the Arduino program
Pastebin - Upload results withe Arduino Yun shield selected in the Arduino program - http://pastebin.com/Pe8hqMYz
PHP script:
<?php include("connect.php"); $link=Connection(); $temp1=$_POST["temp1"]; $hum1=$_POST["hum1"]; $query = "INSERT INTO `tempLog` (`temperature`, `humidity`) VALUES ('".$temp1."','".$hum1."')"; mysql_query($query,$link); mysql_close($link); header("Location: index.php"); ?>
TapeStream:
Code:
Wrong code base, for Yun/Yun shield please use bridge class.
http://www.ibuyopenwrt.com/index.php/2-uncategorised/205-php-mysql-for-process-class
sonnyyu: Mysql, Microsoft SQL, Sybase, Sqlite3, NoSQL-MongoDB, PostgreSQL, DB in Memory (memcached).
http://www.ibuyopenwrt.com/index.php/datalog-db
To do list: Oracle, IBM DB2
|500x281
Yun/Yun shield support a lot of DB directly, no php midware is needed.
sonnyyu: The list of programming language Yun/Yun Shield supports:
  • Erlang (a general-purpose concurrent, garbage-collected programming language and runtime system)
  • Java
  • JavaScript
  • Lua
  • PHP
  • Perl
  • Python
  • Ruby
  • 4th (an imperative stack-based computer programming language and programming environment)
  • eggdrop (Eggdrop is a popular IRC bot and the oldest still in active development)
  • sigscheme (SigScheme is a R5RS Scheme interpreter for embedded use.)
  • slsh (Interpreter for S-Lang scripts)
  • tcl (Tool Command Language)
  • vala (C-sharp like language for the GObje)
  • C
  • C++
  • MIPS Assembly Language
  • Shell Scripts
  • Fortran
TapeStream: ... Problems: - When i upload my sensor and string poster on JUST the Arduino Uno it correctly uploads. But when i have the Yun Shield attached (and the sensor) i get the sync error:
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM9 Using Programmer : arduino Overriding Baud Rate : 115200 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd8 avrdude: stk500_recv(): programmer is not responding
Dragino Yun shield
Setup Dragino and Arduino IDE
That shield talks to the Arduino using the hardware serial pins/instance. That WILL interfere with loading a sketch on the Arduino while the shield is attached.
Nothing you can do about it except remove it when uploading.
This is NOT a programming issue.
PaulS: That shield talks to the Arduino using the hardware serial pins/instance. That WILL interfere with loading a sketch on the Arduino while the shield is attached.
It is not true.
Yun shield + Uno/Leonardo/Mega
You could upload sketch directly via network port (WiFi, Ethernet)
|500x407
Yun shield + Leonardo only
You could upload sketch via USB as well
(image is "Yun shield + Leonardo", has 3 ports to select for uploading)
Thanks to all of you for posting! I really appriciate it!! Heres the new status:
So here is what i did, i downloaded the proper “driver”? So i could choose Arduino - Cards - Arduino Uno - Yun. Then I choose the now network found card under Ports: 4.4.4.4.150 (Yun). I then uploaded again and it asked me for the password, witch was the default draguino.
Here is the problem free upload now:
But it still does not send sensor values to the webserver, any tips on where to start searching for the error? A syslog from the card perhaps?
PS! Just followed this to upgrade it aswell, then i reuploaded the script: https://www.arduino.cc/en/Tutorial/YunSysupgrade
sonnyyu:
Install software php and mysql driver at Yun/Yun shield.
opkg update
opkg install php5-mod-mysqli
opkg install php5-cli
nano /mnt/sda1/db.php
#!/usr/bin/php-cli
<?php
$temperature = $argv[1];
$DBServer = '192.168.0.20';
$DBUser   = 'root';
$DBPass   = 'password';
$DBName   = 'sensors';
$conn = new mysqli($DBServer, $DBUser, $DBPass, $DBName);
// check connection
if ($conn->connect_error) {
  trigger_error('Database connection failed: '  . $conn->connect_error, E_USER_ERROR);
$sql="INSERT INTO sensor_data (temperature) VALUES ($temperature)";
if($conn->query($sql) === false) {
  trigger_error('Wrong SQL: ' . $sql . ' Error: ' . $conn->error, E_USER_ERROR);
"192.168.0.20" is your mysql server 's IP.
chmod 755 /mnt/sda1/db.php
Send test insert data without ATmega32u4:
/mnt/sda1/db.php  80
Make sure mysql has new insert data (80).
Upload ATmega32u4 's code:
#include <Process.h>
int temperature;
 Bridge.begin();  // Initialize Bridge
 int temperature = random(0, 100);
 Process p;
 p.begin("/mnt/sda1/db.php");
 p.addParameter(String(temperature));
 p.run();
 delay(5000);
Thanks a lot again. Not sure how to do all this but will try over the next few days. I only wanted an arduino uno + yun shield, and for it to use some simple code over wan to send sensor strings.
