Arduino UNO + zdm-2ha865 Driver
Hello,
I want to control a NEMA34 servo motor with the ZDM-2HA865 driver and and Arduino-UNO.
The servo motor is moving, with our test code, but really slow.
Some of parameters of functions differ from the original (from factory) values documented, ie.
  • P102 has 145, and the guide establish a value of 45.
  • P104 has 75, and the guide establish 65.
  • P105 has 70, and the guide establish 85.
  • P106 has 60, and the guide establish 50.
Do you believe those values are causing the issue?
Regards and thank you
Miguel
No idea about those numbers, but did you mean stepper motor?
Do you have a suitable power supply?
Why not try using the factory's numbers?
@arduinomaat3,
Welcome.
Your topic was moved to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Thank you
Hello, yes, it's a stepper motor. Yes, we have a suitable power supply and we tried factory's numbers. But I have not the arduino's ground connected to that power suppply. Is there any risk to overload the arduino board if I make that connection (because of the voltage)?
Thanks.
