Arduino board showing light but not detected by laptop. When i am Connecting usb with laptop.
Welcome to the forum
Which Arduino board are you using ?
How do you know it’s not connecting?
Hi! Welcome to the Forum.
You may be using a charge only cable, but it's just a guessing as we have too few information.
I am using arduino uno r3.
And the IDE version is 1.8.19, but that's not the case, if you connect any usb cable, a sound and a signal comes to the computer. It was also coming to my Arduino, but now it's not coming, only the light is on the Arduino board, I've tried using two other computers.
Tried using cable.
But only the light is on but no code is uploading.
And the arduino is not showing on the computer.
Tried using cable.
can you post a photo of your cable
I have deleted your other cross-post @utso234 .
Cross-posting is against the Arduino forum rules. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting can result in a suspension from the forum.
In the future, please only create one topic for each distinct subject matter. This is basic forum etiquette, as explained in the "How to get the best out of this forum" guide. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
It sounds like you got part of your board burned.
I remember to have seen some possible loopback tests provided by @sterretje in another post. Maybe can give us some light.
Loop back test will not help if the computer does not show a device in Windows device manager.
try using diffrent cable
what happend
