Arduino Upload, Help!
I have been able to compile, but when I upload, an error comes up saying:
Binary sketch size: 10,786 bytes (of a 30,720 byte maximum)
processing.app.SerialNotFoundException: Serial port 'COM1' not found. Did you select the right one from the Tools > Serial Port menu?
at processing.app.Serial.(Serial.java:191)
at processing.app.Serial.(Serial.java:77)
at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:77)
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:175)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:619)
I am also not available to choose a serial port, for it is grayed out..
Unplug then replug usb then serial com shouldn't be grayed out. If that doesn't work then try another usb port...
I tried unplugging and replugging, but there is no change, and Serial Port is still grayed out. I also did the same for the other usb ports but it still won't work
