Arduino: 1.8.5 (Windows 7), Board: "LilyPad Arduino, ATmega328P"
Sketch uses 1046 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM3": The system cannot find the file specified.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Please reply for the solution.Arduino: 1.8.5 (Windows 7), Board: "LilyPad Arduino, ATmega328P"
An error occurred while uploading the sketch
Is that error for the ONLINE or the desktop IDE ?
Looks like the desktop.
Also enable VERBOSE for the upload to add more detail for the error.
Make sure nothing else is connected to the board 0 & 1 pins during upload.
Is it a CLONE or a REAL arduino ? (doesnt matter but the advice will change)
ITS IDE.
I ENABLED VERBOSE AND ITSHOWS MORE DETAILS ABOUT IT. Arduino: 1.8.5 (Windows 7), Board: "LilyPad Arduino, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=arduino:avr:lilypad:cpu=atmega328 -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_663919 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_874597 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Dell\Downloads\gesture_control_robot_final\gesture_control_robot_final.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Dell\Documents\Arduino\libraries -fqbn=arduino:avr:lilypad:cpu=atmega328 -ide-version=10805 -build-path C:\Users\Dell\AppData\Local\Temp\arduino_build_663919 -warnings=none -build-cache C:\Users\Dell\AppData\Local\Temp\arduino_cache_874597 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Dell\Downloads\gesture_control_robot_final\gesture_control_robot_final.ino
Using board 'lilypad' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10805 -DARDUINO_AVR_LILYPAD -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919\sketch\gesture_control_robot_final.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10805 -DARDUINO_AVR_LILYPAD -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919\sketch\gesture_control_robot_final.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=8000000L -DARDUINO=10805 -DARDUINO_AVR_LILYPAD -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919\sketch\gesture_control_robot_final.ino.cpp" -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919\sketch\gesture_control_robot_final.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919/gesture_control_robot_final.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919\sketch\gesture_control_robot_final.ino.cpp.o" "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919/..\arduino_cache_874597\core\core_arduino_avr_lilypad_cpu_atmega328_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\Dell\AppData\Local\Temp\arduino_build_663919" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919/gesture_control_robot_final.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919/gesture_control_robot_final.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919/gesture_control_robot_final.ino.elf" "C:\Users\Dell\AppData\Local\Temp\arduino_build_663919/gesture_control_robot_final.ino.hex"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b57600 -D -Uflash:w:C:\Users\Dell\AppData\Local\Temp\arduino_build_663919/gesture_control_robot_final.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude done.
PLEASE REPLY FOR IT IMMEDIATELY I HAVE VERY LESS TIME.
Thank you.
Remove anything that is connected to the Arduino.
Ensure you use a USB 2.0 port.
Try another cable.
You failed to answer my question about which IDE you were using but it seems its the desktop so lets get this moved elsewhere.
BTW we are all just arduino users not Arduino staff so use of CAPS and asking for an immediate answer doesn't sit well with a lot of us.
