Arduino Uploading Problem On Raspberry Pi
Hey, alright so I've been facing this issue a lot, and does the Arduino software actually work on the raspberry pi, if so then I'am still facing the issue of an uploading problem, the error message is this
Arduino: 1.9.0-beta (Linux), Board: "Arduino/Genuino Uno"
/home/pi/Arduino/sketch_apr27a/sketch_apr27a.ino: In function 'void setup()':
/home/pi/Arduino/sketch_apr27a/sketch_apr27a.ino:67:24: warning: invalid conversion from 'int*' to 'uint8_t {aka unsigned char}' [-fpermissive]
pinMode(Inputs, INPUT);
In file included from sketch/sketch_apr27a.ino.cpp:1:0:
/home/pi/Downloads/arduino-PR-beta1.9-BUILD-44/hardware/arduino/avr/cores/arduino/Arduino.h:133:6: note: initializing argument 1 of 'void pinMode(uint8_t, uint8_t)'
void pinMode(uint8_t, uint8_t);
Sketch uses 2224 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 208 bytes (10%) of dynamic memory, leaving 1840 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "COM1": No such file or directory
An error occurred while uploading the sketch
option enabled in File -> Preferences
Now I have run very simple code to figure out if the code was the problem, and I found the very same uploading problem. Then again does anybody know how to manually install the drivers, because I've checked under the ttyAMC like the troubleshooting guide told me to, and found that I don't have the same specified driver. Now another website has also told me to disable the serial console
Website : razzpisampler
Does that work?
Select the port of your Arduino from the Arduino IDE's Tools > Port menu.
Dr_Fish:
Works for me.
(deleted)
