Arduino using 12v npn sensor
What's the best way to use a 12 volt npn sensor the sensor is using a external power
Do you have a data sheet for the sensor? We need to know what type of output it has.
Mikeh23:
The best way would be to power it with 5V.
This it the data sheet
The data sheet is for several models. Which do you have?
Yea sorry it's M18-3VNLPC-2M
Unfortunately I don't really understand the circuits as sketched in the data sheet.
In general an NPN output (aka open collector) can be connected directly to a digital pin, with the internal pull-up enabled. This output connects to GND when active (giving a logical low), is floating when not active (and the pull-up ensures a logical high).
If you want to be sure, add a diode pointing away from your digital pin, so any higher voltage can never reach your Arduino.
Remember to connect Arduino GND to sensor GND.
