Hello all,
I'm working on a project, making a glove that will influence my music on the way i am moving my hand.
So i started with a 3-axis accelerometer and 5 flex sensors, but now i only see tutorials where they use the analog pins for both the flex sensors and the accelerometer (so i need 8 of them) but my arduino uno board only has 6 analog pins. i tried to put them on the digital pins but the values changed in range or even didn't change at all if movement occurred. as i am not that experienced i also don't know if this has something to do with the digital pin code or that i have to add some things in my code or in the circuit or whatever. so my question.
Will it make a big difference or is it even possible to use the digital pins for accelerometers or flex sensors ?
Thanks in advance !
