i am using sdfat library from the below link
https://code.google.com/p/beta-lib/downloads/detail?name=SdFatBeta20130621.zip&can=2&q=
* Example use of two SD cards.
#include <SdFat.h>
#include <SdFatUtil.h>
#if !USE_MULTIPLE_CARDS
#error You must set USE_MULTIPLE_CARDS nonzero in SdFatConfig.h
#endif
SdFat sd1;
const uint8_t SD1_CS = 10; // chip select for sd1
SdFat sd2;
const uint8_t SD2_CS = 9; // chip select for sd2
const uint8_t BUF_DIM = 100;
uint8_t buf[BUF_DIM];
const uint32_t FILE_SIZE = 1000000;
const uint16_t NWRITE = FILE_SIZE/BUF_DIM;
// print error msg, any SD error codes, and halt.
// store messages in flash
#define errorExit(msg) errorHalt_P(PSTR(msg))
#define initError(msg) initErrorHalt_P(PSTR(msg))
while (!Serial) {} // wait for Leonardo
PgmPrint("FreeRam: ");
Serial.println(FreeRam());
// fill buffer with known data
for (int i = 0; i < sizeof(buf); i++) buf[i] = i;
PgmPrintln("type any character to start");
while (Serial.read() <= 0) {}
delay(400); // catch Due reset problem
// disable sd2 while initializing sd1
pinMode(SD2_CS, OUTPUT);
digitalWrite(SD2_CS, HIGH);
// initialize the first card
if (!sd1.begin(SD1_CS)) {
sd1.initError("sd1:");
// create DIR1 on sd1 if it does not exist
if (!sd1.exists("/DIR1")) {
if (!sd1.mkdir("/DIR1")) sd1.errorExit("sd1.mkdir");
// initialize the second card
if (!sd2.begin(SD2_CS)) {
sd2.initError("sd2:");
// create DIR2 on sd2 if it does not exist
if (!sd2.exists("/DIR2")) {
if (!sd2.mkdir("/DIR2")) sd2.errorExit("sd2.mkdir");
// list root directory on both cards
PgmPrintln("------sd1 root-------");
sd1.ls();
PgmPrintln("------sd2 root-------");
sd2.ls();
// make /DIR1 the default directory for sd1
if (!sd1.chdir("/DIR1")) sd1.errorExit("sd1.chdir");
// make /DIR2 the default directory for sd2
if (!sd2.chdir("/DIR2")) sd2.errorExit("sd2.chdir");
// list current directory on both cards
PgmPrintln("------sd1 DIR1-------");
sd1.ls();
PgmPrintln("------sd2 DIR2-------");
sd2.ls();
PgmPrintln("---------------------");
// remove RENAME.BIN from /DIR2 directory of sd2
if (sd2.exists("RENAME.BIN")) {
if (!sd2.remove("RENAME.BIN")) {
sd2.errorExit("remove RENAME.BIN");
// set the current working directory for open() to sd1
sd1.chvol();
// create or open /DIR1/TEST.BIN and truncate it to zero length
SdFile file1;
if (!file1.open("TEST.BIN", O_RDWR | O_CREAT | O_TRUNC)) {
sd1.errorExit("file1");
PgmPrintln("Writing TEST.BIN to sd1");
// write data to /DIR1/TEST.BIN on sd1
for (int i = 0; i < NWRITE; i++) {
if (file1.write(buf, sizeof(buf)) != sizeof(buf)) {
sd1.errorExit("sd1.write");
// set the current working directory for open() to sd2
sd2.chvol();
// create or open /DIR2/COPY.BIN and truncate it to zero length
SdFile file2;
if (!file2.open("COPY.BIN", O_WRITE | O_CREAT | O_TRUNC)) {
sd2.errorExit("file2");
PgmPrintln("Copying TEST.BIN to COPY.BIN");
// copy file1 to file2
file1.rewind();
uint32_t t = millis();
while (1) {
int n = file1.read(buf, sizeof(buf));
if (n < 0) sd1.errorExit("read1");
if (n == 0) break;
if (file2.write(buf, n) != n) sd2.errorExit("write2");
t = millis() - t;
PgmPrint("File size: ");
Serial.println(file2.fileSize());
PgmPrint("Copy time: ");
Serial.print(t);
PgmPrintln(" millis");
// close TEST.BIN
file1.close();
// rename the copy
file2.close();
if (!sd2.rename("COPY.BIN", "RENAME.BIN")) {
sd2.errorExit("sd2.rename");
PgmPrintln("Done");
void loop() {}
i am getting error as
FreeRam: 439
DIR1/
DIR2/
TEXT.BIN
COPY.BIN
error: file1
SD errorCode: 0X13,0XFF
can anyone let me know what the problem is...
