im making a project that consists on a arduino + ethernet shield + leds + UV sensor and i need to send the data (that i recieve from the sensor) to a mysql database
#include <Wire.h>
#include “Adafruit_SI1145.h”
#include <SPI.h>
#include <Ethernet.h>//leds
#ifdef AVR
#include <avr/power.h>
#endif//arduino pin usado + leds nr pins usados
#define PIN 6
#define NUMPIXELS 20Adafruit_SI1145 uv = Adafruit_SI1145();
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);//delay leds
int delayval = 25; // delay for half a secondbyte mac = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };// Enter the IP address for Arduino, as mentioned we will use 192.168.0.16
// Be careful to use , insetead of . when you enter the address here
IPAddress ip(192,168,137,11);IPAddress server(192,168,137,1); // IMPORTANT: If you are using XAMPP you will have to find out the IP address of your computer and put it here (it is explained in previous article). If you have a web page, enter its address (ie. “www.yourwebpage.com”)
//char server = “localhost”;// Initialize the Ethernet server library
EthernetClient client;void setup() {
// Serial.begin starts the serial connection between computer and Arduino
pixels.begin();//start UV sensor
if (! uv.begin()) {
Serial.println(“UV desligado”);
}Serial.println (“UV ligado”);
// start the Ethernet connection
Ethernet.begin(mac, ip);}
if (client.connect(server,80) > 0) {while(client.connected()) {
// get data from sensor
float UVindex = uv.readUV();
UVindex /= 100.0;
Serial.print(“UV BEFORE LEDS/DB”);Serial.println(UVindex);if(UVindex==0.02){
Serial.print("UV: "); Serial.println(UVindex);for(int i=0;i<NUMPIXELS;i++){
pixels.setPixelColor(i, pixels.Color(150,0,0)); // Moderately bright green color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds)
else if(UVindex == 0.01){
pixels.setPixelColor(i, pixels.Color(0,150,0)); // Moderately bright green color.
delay(delayval); // Delay for a period of time (in milliseconds)}
}else if(UVindex == 0.03){
pixels.setPixelColor(i, pixels.Color(0,0,150)); // Moderately bright green color.
}// Header start
Serial.println(“connected”);
client.print(“GET /arduino_client_UV_VALUES/pap/getUV.php?”);
client.print(“uv=”);
client.print(UVindex);
client.println(" HTTP/1.1");
client.println(“Host: 192.168.137.1”);
//client.println(“Connection: close”);
client.println();
// Header finishdelay(1000);
Serial.println(server);
Serial.println(“connection failed”);
}// Give the server some time to recieve the data and store it. I used 10 seconds here. Be advised when delaying. If u use a short delay, the server might not capture data because of Arduino transmitting new data too soon.
This is my code… my problem is that the connection always fails, i dont know what to do. can someone help me?
Everything works except the connection
