arduino+vb6
hi Glennmars ... just like michael_x says... It's time you slowed down and started to learn to use the VB and Arduino IDE's
If you don't know even how to set a break point or view a debug window, then you must learn.
If what you are doing is just a one time project, then I think you might be able to work your way through it by just using examples off the internet. If you want to continue you just have to learn your code and that takes time and a hell of a lot of patience.
You already have what you need for the communication between VB and Arduino. That is kind of the hard part. The rest is learning to code in VB6
Good luck
Thanks guys..i appreciate your helpfulness :slight_smile:
I can’t imagine how I passed by that code without noticing that a double end sub appears, :cold_sweat: well thanks again..
RPCoyle thanks, I understand what you mean..hehehe, I just can’t fully understand those other terms in vb that’s why I keep on asking..sorry for that.!. :relaxed:
Anyways, I’m still confuse on the code you posted..just feel free to make this clear to me but if not I understand..
Hmmp, about this code:
strt = InStr(str, "<") + 1
  fin = InStr(str, ">")
  If (fin - strt) <= 0 Then
     Exit Function
  Else
      ColorStr =  Mid(str, strt, (fin - strt))
  End If
You should be able to piece this together and get it working.
do you mean that, that code is inserted one by one or they belong to a separate places of the code then i should only determine if where this code fits.?. :zipper_mouth_face:
Finally, the code of my arduino goes like this:
Serial.println ("<Y>");
Serial.print(ColorStr);
is this right.?.or it should be like this:
Serial.print("< ");
 Serial.print(ColorStr);       // output to computer USB port
Serial.println(">");
i was confused for that..
Here is some VB6 code I put together from your code...
I added a text box as Text1 so that you would know what the pressure is
Option Explicit
' this is added to allow the sleep call
Private Declare Sub Sleep Lib "kernel32" ( _
    ByVal dwMilliseconds As Long)
Private Sub Form_Load()
  With MSComm1
        If .PortOpen Then .PortOpen = False
        .CommPort = 7 ' *************** YOU MAY NEED TO CHANGE THIS OR ADD MY CODE TO FIND THE COM PORT************************
        .Settings = "9600,N,8,1"
        .DTREnable = True
        .RTSEnable = True
        .RThreshold = 4
        .SThreshold = 3
        .PortOpen = True
  End With
End Sub
Private Sub LEDOn(col As Long)
 Shape1.BackColor = col
End Sub
Private Sub LEDOff()
 Shape1.BackColor = &HFFFFFF
End Sub
Private Sub MSComm1_OnComm()
Dim strData As String
Static strBuffer As String
Dim strWords() As String
Dim intPos As Integer
Dim boComplete As Boolean
Dim mystr As String
        Sleep 1000 ' this waits one second between readings from the Arduino
        mystr = "" ' set the string to nothing
        mystr = MSComm1.Input
            intPos = InStr(mystr, "<")
            If intPos > 0 Then
                Select Case Mid(mystr, 1, 3) ' strip off the CR/LF
                    Case "<Y>"
                        Text1.Text = ("The pressures value is 80 psi")
                        Call LEDOn(&HFFFF&) ' this is in hex
                    Case "<B>"
                        Text1.Text = ("The pressures value is 60 psi")
                        Call LEDOn(&HFF0000) ' this is in hex
                    Case "<R>"
                        Text1.Text = ("The pressures value is 20 psi")
                        Call LEDOn(&HFF&) ' this is in hex
                    Case "<G>"
                        Text1.Text = ("The pressures value is 40 psi")
                        Call LEDOn(&HFF00&) ' this is in hex
                    Case Else
                       Call LEDOff
                End Select
         End If
End Sub
here is the Arduino code I used to send the info to the VB code, based on your code.
I eliminated some of the logic in your rev because I did not know what it did, and I wonder if you did. It seemed to have njot much to do with what you are looking for. You can put it back in is you need it.
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  pinMode(2, INPUT);
  pinMode(3, INPUT);
  pinMode(4, INPUT);
  pinMode(5, INPUT);
  pinMode(7, OUTPUT);
  Serial.begin (9600);
  int a = digitalRead (2);
  int b = digitalRead (3);
  int c = digitalRead (4);
  int d = digitalRead (5);
  //digitalWrite (7,LOW);
    if (a == HIGH)
      digitalWrite (9, HIGH);
      Serial.println ("<R>");
      delay (200);
      digitalWrite (7, HIGH);
      delay (400);
      digitalWrite (7, LOW);
    else if (a == LOW)
      digitalWrite (9, LOW);
    if (b == HIGH)
      digitalWrite (10, HIGH);
      Serial.println ("<G>");
      delay (200);
      delay (400);
      delay (200);
      delay (400);
    else if(b==LOW)
      digitalWrite (10, LOW);
    if (c == HIGH)
      digitalWrite (11, HIGH);
      Serial.println ("<B>");
      delay (200);
      delay (400);
      delay (200);
      delay (400);
      delay (200);
      delay (400);
    else if (c==LOW)
      digitalWrite (11, LOW);
    if (d == HIGH)
      digitalWrite (12, HIGH);
      delay (200);
    else if (d==LOW)
      digitalWrite (12, LOW);
It works for me... it should work for you... give it a try!
thanks for your reply RPCoyle..how great you are :wink:
what you posted on the code on my arduino is same as mine too, but i was so confused about this code that's why i clarify it to you..
yes, i know this declaration, well thanks for specifying.. :slight_smile:
     Exit Function
  Else
  End If
i just want to clarify if the code above should be still inserted or this code below will do it's function:
            If intPos > 0 Then
thanks :wink:
just use the code that I posted last... the other code snippets were examples based on some of the things I did to get a temperature reading to control a kiln
okay thanks RPcoyle :%
i'm so excited to try the code..heheheh, thanks again :smiley:
hi again.!.
RPCoyle, your right that i should add the code you posted in the code below because when i use to debug this it never finds the comport1, (i already change the commport 7 to commport 1)..let us say that i should close the arduino first before it runs..now, i edit the code and add your code but when i debug the vb application an error prompts me that the < FoundIt does not define.> i search through the net some samples on how it was going to be declared but still i find nothing..Perhaps, you know this much will you please help me again for this.. :disappointed_relieved:
 With MSComm1
        .DTREnable = True
        .RTSEnable = True
        .RThreshold = 4
        .SThreshold = 3
        .PortOpen = True
Thanks!
Which is your COM port then ?
You see/set it in the Arduino IDE, Serial Monitor, and see it when you locate your Arduino among "Printers, Devices" in your Windows Control Panel.
For e.g. COM3 you should modify that line to
.CommPort = 3 ' *************** YOU MAY NEED TO CHANGE THIS OR ADD MY CODE TO FIND THE COM PORT************************
Alternatively you might try to understand the hint
this refers to
' find USB port
ComFail = False
FailErr = False
For n = 1 To 16
  If MSComm1.PortOpen = True Then MSComm1.PortOpen = False
   On Error Resume Next
   MSComm1.CommPort = n
in Entry 16. Can you guess what these lines are doing ?
hi again!..i feel sorry for the delay..
michael_x..i can see already the comport number when i use to plug the arduino it's comport 1...yet, i set the comport as a .CommPort = 1 and as what you said that i should change or add your code for me to find the comport but when i add your code it prompts an error on:
FoundIt = False          // in this code an error occur  stating that it was not being defined...
' find USB port
ComFail = False
FailErr = False
For n = 1 To 16
' find USB port
ComFail = False
FailErr = False
For n = 1 To 16
base on my understanding, this line of codes set for finding the comport...
It is hard to believe that your board shows up as COM 1. The computer usually has something at COM 1.
but if the Arduino IDE says it is on COM 1 and you are able to see your output coming through over the serial monitor then it is on COM 1 and the code I gave you should work as long as the output is unclosed in "<" and ">"
If you are mixing the code I gave you with the code Glen gave you, then you might have problems, even though his code is OK. He just uses a "With" statement to streamline the code and it might be a little harder for you to figure out, even though you started out that way. I don't think you understand the fine points.
If you are just using my code, then i really have no idea what the problem might be.
hello..
  With MSComm1
        .CommPort = 2         // i change the comport into 2 as what i had seen in serial monitor of arduino
        .DTREnable = True
        .RTSEnable = True
        .RThreshold = 4
        .SThreshold = 3
        .PortOpen = True
  End With
End Sub
RPCoyle, i used your code and yet it works but it goes back to the problem before that when i try to hit the switch button the Led connected in pin 9 will not light and so on...it seems nothing happens when i use to run the vb application..the communication between arduino to vb are not functioning or we may say that i can't access the input from arduino to vb...but if i try the code below:
Private Declare Sub Sleep Lib "kernel32.dll" (ByVal dwMilliseconds As Long)
Dim Str As String
MSComm1.Settings = "9600,N,8,1"
FoundIt = False
' find USB port
ComFail = False
FailErr = False
For n = 1 To 16
   MSComm1.InputLen = 0
   If MSComm1.CommID > 0 Then
    strt = InStr(Str, "<") + 1
     fin = InStr(Str, ">")
     If (fin - start) <= 0 Then
     Else: ColorStr = Mid(Str, start, (fin - strt))
     End If
If MSComm1.PortOpen = False Then MsgBox "Controller Not functioning , Please check USB connection", vbCritical, "": ComFail = True: Exit Sub
jump:
     '   your case statement
     ' Debug.Print ">"; Str; "<";
     Select Case (Str) ' set a break point here so you can step through the case statement
   Case "A"
     Call LEDOn(vbRed)
   Case "B"
     Call LEDOn(vbGreen)
   Case "C"
     Call LEDOn(vbBlue)
   Case "D"
     Call LEDOn(vbYellow)
   Case Else
      Call LEDOff
End Select
End If
'Exit Function
End Sub
Shape1.FillColor = col
End Sub
Shape1.FillColor = vbWhite
End Sub
i can access the input from arduino when i run the vb application..
below are the code i edited which come from you..i add the code you posted in previous to find the port but i guess there still lacking in this..
Option Explicit
Dim mystr As String
  With MSComm1
 FoundIt = False         // when i run this vb app. an error occurs here stating not define...
 'find USB port
ComFail = False
FailErr = False
       .CommPort = 2  ' *************** YOU MAY NEED TO CHANGE THIS OR ADD MY CODE TO FIND THE COM PORT************************
        .InputLen = 0
        .DTREnable = True
        .RTSEnable = True
        .RThreshold = 4
        .SThreshold = 3
        .PortOpen = True
  End With
End Sub
End Sub
End Sub
Dim mystr As String
            If intPos > 0 Then
                    Case "<Y>"
                    Case "<B>"
                    Case "<R>"
                    Case "<G>"
                    Case Else
                       Call LEDOff
                End Select
         End If
End Sub
i appreciate most your help! :wink:
Dim mystr As String
Dim FoundIt As Integer
Dim ComFail As Integer
Dim FailErr As Integer
Dim n As Integer
FoundIt = False
' find USB port
ComFail = False
FailErr = False
For n = 1 To 1
  If MSComm1.PortOpen Then MSComm1.PortOpen = False
   MSComm1.CommPort = 1
   MSComm1.DTREnable = True
    MSComm1.RThreshold = 4
    MSComm1.SThreshold = 3
Next
End Sub
the above code is what i edit using your code to find the comport...
  1. another thing is that, when i run the vb application and then hit the button it prompts an error in which i enclose in quote...then it points on the code above where i put a comment
Run-time error reading '8020':
Error reading comm device
Dim mystr As String
        mystr = MSComm1.Input  ////in this area the error points out
            If intPos > 0 Then
                    Case "<Y>"
i need some help on how to fix this..
thanks!
Gosh Glen, we seem to be going around in circles.
The code I gave you in reply #22 works... I tried it, it works with your Arduino script.
You still seem to be thrashing around trying to get the VB app to read COM 1.
The code should work if you are sending data from the Arduino to the VB on COM 1.
Even if the data doesn't match what VB is looking for, it should not give you a error message. it should just do nothing.
Are you sure that the Arduino board is sending data out on COM 1? When you open Tools/Serial Port from the menu does it say COM 1 and can you then look at the serial monitor sending out data on this port?
I guess the other question is... is your Arduino board a real Arduino board made by the folks in Italy or is it some clone made by some other company. I bought a couple of clones from China that had different chips for serial communication and I had trouble with them using the Arduino 1.0 rev and had to go back to rev .021 to even get a download.
This is probably not your problem, but I can see nothing much else to try.
Oh buy the way, it seems like way back some time you actually did get the VB to connect with the Arduino. Is that true or just my imagination?
hi RPCoyle am sorry if i keep on inquiring 'coz until now still i find nothing..
base on what you said, i had two installer of arduino the latest version which is the 1.0 and also the .0021....i used the old version which is the .0021 and yet it works on the arduino..i can see in the serial monitor the and so on when i press the switch button but when i run the vb6 application and press the button switch nothing happens..seems it goes back to the problem before that when i run the arduino then next to that is the vb app then as i pressed the button switch the LED will not flash or nothing happens to it... :disappointed_relieved:
hope you understand me.. :frowning:
thanks
hello again...
i just want to show you my edited code..this code will be able to access the switch button which is connected in arduino when i run the vb application..i just inserted your code RPCoyle in finding the commport...just take a look if what is lacking on this because i can only access the button switch but nothing sends to vb application or we may say the circle doesn't fill any color.... :sweat_smile:
Option Explicit
Dim mystr As String
Dim n As Integer
FoundIt = False
' find USB port
ComFail = False
FailErr = False
For n = 1 To 1
   'MSComm1.DTREnable = True
    'MSComm1.RThreshold = 4
    'MSComm1.SThreshold = 3
Next
End Sub
End Sub
End Sub
Dim mystr As String
            If intPos > 0 Then
                    Case "<Y>"
                    Case "<B>"
                    Case "<R>"
                    Case "<G>"
                    Case Else
                       Call LEDOff
                End Select
         End If
End Sub
thanks :wink:
Sorry Glen, we are still going in circles. I asked you what COM port showed up in the Tools/Serial Port menu in the Arduino IDE when you are seeing the correct data coming out on the Serial Monitor window.
Answer this question, and then maybe we can go further.
actually, you can set the comport on any vacant or not in used port...right.?. now base on what you've ask RPCoyle it's Commport 1..whenever i open the arduino then go to tools/serial port it's comport 1..then when i open the serial monitor it's still com1... but i can change this if ever i want by just right clicking the computer/properties/device manager/port(COM & LPT)/port settings/advance/comport number..
You may see more than one com port listed in the tool/serial port menu, but only one com port will work to give you the output from the board. you can not set the comport for the Arduino to any vacant or not in used port. If you do not select the correct port you will not see anything on the serial monitor.
The only valid port for you is the com port that shows the correct values on the serial monitor for your board... Which com port selected from the tool/serial port menu gives you the correct output on the serial monitor?
it's comport 1 RpCoyle...i can see on the serial monitor the "" and the rest of this when i hit the button with the commport value which is commport1...
how about correcting those components i put on my vb.?.just try to correct this:
as i open the vb application first thing i did was inserting the component, i open the Project/components/controls/(i check the) micsrosoft comm control 6.0..after that i put the component that appears on the toolbox picture like a telephone on the form, then i put a textbox and a shape on a form also..
my regard is, is this all right.?. :roll_eyes:
