Currently, I'm using Visual Studio 2010 to write c++ code. Also the visual assisst is installed. They provide a friendly GUI for the development. Compared to Aruduino official IDE, VS has some obvious advantages. Such as the C++ key words are highlighted, it is easy to go to the definition of the library functions, and so on.
I want to use VS to write the Arduino code. Is there a workarond to implement this?
you need to write a plugin for the VS environment that calls the Arduino compiler. I think VS does not allows another compiler and as far as I known it doesn't cross compile.
Another option is to use SharpDevelop, not as good as VS but opensource so you have something to spend the coming long winternights :)
Starting point maybe http://wiki.sharpdevelop.net/CPPSupportPage.ashx
This isn't a direct answer to your question, but faced with a similar quest I installed code::blocks. It is a free C++ IDE which can be configured for the AVR toolchain used by Arduino, and includes features like syntax highlighting, intellisense and a lot of other good stuff.
