Hi
I’m having trouble with a voltmeter project. I currently have a voltmeter reading 5 volts on a seven segment display. I would like the display to turn on for 3 seconds when i press a button as well as the transistor that powers the circuit which is being read.
So far the code i have turns the display on when i press the button, so i have to hold it down.
I have read about millis function but i have no idea how to integrate it into the IF function. Delay function does not work as it turns off the display…
any help appreciated
int digit1 = 4; //PWM Display pin 12
int digit2 = 5; //PWM Display pin 9
int segA = 6; //Display pin 11
int segB = 7; //Display pin 7
int segC = 8; //Display pin 4
int segD = 9; //Display pin 2
int segE = 10; //Display pin 1
int segF = 11; //Display pin 10
int segG = 12; //Display pin 5
int transistor = 3;
const int DisplayButton = 2;
int buttonState = 0;
int potpin = A0; //potentiometer analog pin
int val; //value for analog input
int number;
pinMode(segA, OUTPUT);
pinMode(segB, OUTPUT);
pinMode(segC, OUTPUT);
pinMode(segD, OUTPUT);
pinMode(segE, OUTPUT);
pinMode(segF, OUTPUT);
pinMode(segG, OUTPUT);
pinMode(digit1, OUTPUT);
pinMode(digit2, OUTPUT);
pinMode(transistor, OUTPUT);
buttonState = digitalRead(DisplayButton);
if (buttonState == HIGH) {
digitalWrite(transistor, HIGH);
val = analogRead(potpin);
val = map(val, 0, 1023, 0, 5);
displayNumber(val);
else {
delay(10);
digitalWrite(transistor, LOW);
void displayNumber(int toDisplay) {
#define DISPLAY_BRIGHTNESS 5000
#define DIGIT_ON LOW
#define DIGIT_OFF HIGH
long beginTime = millis();
for(int digit = 2 ; digit > 0 ; digit--) {
//Turn on a digit for a short amount of time
switch(digit) {
case 1:
digitalWrite(digit1, DIGIT_ON);
case 2:
digitalWrite(digit2, DIGIT_ON);
//Turn on the right segments for this digit
lightNumber(toDisplay % 10);
toDisplay /= 10;
delayMicroseconds(DISPLAY_BRIGHTNESS); //Display this digit for a fraction of a second (between 1us and 5000us, 500 is pretty good)
//Turn off all segments
lightNumber(10);
// //Turn off all digits
digitalWrite(digit1, DIGIT_OFF);
digitalWrite(digit2, DIGIT_OFF);
while( (millis() - beginTime) < 10) ; //Wait for 20ms to pass before we paint the display again
//Given a number, turns on those segments
//If number == 10, then turn off number
void lightNumber(int numberToDisplay) {
// may be need invert
#define SEGMENT_ON HIGH
#define SEGMENT_OFF LOW
switch (numberToDisplay){
case 0:
digitalWrite(segA, SEGMENT_ON);
digitalWrite(segB, SEGMENT_ON);
digitalWrite(segC, SEGMENT_ON);
digitalWrite(segD, SEGMENT_ON);
digitalWrite(segE, SEGMENT_ON);
digitalWrite(segF, SEGMENT_ON);
digitalWrite(segG, SEGMENT_OFF);
case 1:
digitalWrite(segA, SEGMENT_OFF);
digitalWrite(segD, SEGMENT_OFF);
digitalWrite(segE, SEGMENT_OFF);
digitalWrite(segF, SEGMENT_OFF);
case 2:
digitalWrite(segC, SEGMENT_OFF);
digitalWrite(segG, SEGMENT_ON);
case 3:
case 4:
case 5:
digitalWrite(segB, SEGMENT_OFF);
case 6:
case 7:
case 8:
case 9:
case 10:
