Today I received my products and started to hook them up. After loading some sample code from the Macetech site and wiring the shiftbrite to the shiftbrite shield they worked great. Now I'm trying to not use pins 10, 11, 12, & 13 for the shiftbrite because they are required for the Ethernet shield. So I modified the Macetech program for pins 3, 4, 5, & 6. Then rewired the LI, CI, EI, & DI pins leaving the Gnd and V+ on the shiftbrite shield. Once I loaded the modified program back into the Arduino the shiftbright let its smoke out. Below is a copy of the code I used. Do you know of a better way to use other outputs for this application? Any help would be greatly appreciated.
/* Ports and Pins
Direct port access is much faster than digitalWrite.
You must match the correct port and pin as shown in the table below.
Arduino Pin Port Pin
13 (SCK) PORTB 5
12 (MISO) PORTB 4
11 (MOSI) PORTB 3
10 (SS) PORTB 2
9 PORTB 1
8 PORTB 0
7 PORTD 7
6 PORTD 6
5 PORTD 5
4 PORTD 4
3 PORTD 3
2 PORTD 2
1 (TX) PORTD 1
0 (RX) PORTD 0
A5 (Analog) PORTC 5
A4 (Analog) PORTC 4
A3 (Analog) PORTC 3
A2 (Analog) PORTC 2
A1 (Analog) PORTC 1
A0 (Analog) PORTC 0
// Defines for use with Arduino functions
#define clockpin 4 // CL
#define enablepin 5 // BL
#define latchpin 3 // XL
#define datapin 6 // SI
// Defines for direct port access
#define CLKPORT PORTD
#define ENAPORT PORTD
#define LATPORT PORTD
#define DATPORT PORTD
#define CLKPIN 4
#define ENAPIN 5
#define LATPIN 3
#define DATPIN 6
// Variables for communication
unsigned long SB_CommandPacket;
int SB_CommandMode;
int SB_BlueCommand;
int SB_RedCommand;
int SB_GreenCommand;
// Define number of ShiftBrite modules
#define NumLEDs 2
// Create LED value storage array
int LEDChannels[NumLEDs][3] = {0};
// Set pins to outputs and initial states void setup() {
pinMode(datapin, OUTPUT);
pinMode(latchpin, OUTPUT);
pinMode(enablepin, OUTPUT);
pinMode(clockpin, OUTPUT);
digitalWrite(latchpin, LOW);
digitalWrite(enablepin, LOW);
SPCR = (1<<SPE)|(1<<MSTR)|(0<<SPR1)|(0<<SPR0);
// Load values into SPI register
void SB_SendPacket() {
if (SB_CommandMode == B01) {
SB_RedCommand = 127;
SB_GreenCommand = 110;
SB_BlueCommand = 110;
SPDR = SB_CommandMode << 6 | SB_BlueCommand>>4;
while(!(SPSR & (1<<SPIF)));
SPDR = SB_BlueCommand<<4 | SB_RedCommand>>6;
SPDR = SB_RedCommand << 2 | SB_GreenCommand>>8;
SPDR = SB_GreenCommand;
// Latch values into PWM registers
void SB_Latch() {
delayMicroseconds(1);
LATPORT += (1 << LATPIN);
//ENAPORT += (1 << ENAPIN);
//ENAPORT &= ~(1 << ENAPIN);
LATPORT &= ~(1 << LATPIN);
// Send all array values to chain
void WriteLEDArray() {
SB_CommandMode = B00; // Write to PWM control registers
for (int i = 0; i<NumLEDs; i++) {
SB_RedCommand = LEDChannels*[0] & 1023;*
SB_GreenCommand = LEDChannels*[1] & 1023;
SB_BlueCommand = LEDChannels[2] & 1023;
SB_SendPacket();
_ }*_
* SB_Latch();*
* SB_CommandMode = B01; // Write to current control registers*
* for (int z = 0; z < NumLEDs; z++) SB_SendPacket(); *
* SB_Latch();*
// Fade between two colors at specified interval void fadeall(int rate, int fromred, int fromgreen, int fromblue, int tored, int togreen, int toblue) {
for (int i = 0; i < 33; i++) {
* for (int j1 = 0; j1 < NumLEDs; j1++) {*
_ LEDChannels[j1][0] = (fromred * (32 - i) + tored * i)/32;
LEDChannels[j1][1] = (fromgreen * (32 - i) + togreen * i)/32;
LEDChannels[j1][2] = (fromblue * (32 - i) + toblue * i)/32;
* }*_
* WriteLEDArray();*
* delay(rate);*
* fadeall(20,0,0,0,1023,0,0);*
* fadeall(20,1023,0,0,0,1023,0);*
* fadeall(20,0,1023,0,0,0,1023);*
* fadeall(20,0,0,1023,1023,0,0);*
* fadeall(20,1023,0,0,0,0,0);*
* delay(500);*
* fadeall(60,0,0,0,0,0,1023);*
* delay(500);*
* fadeall(60,0,0,1023,0,0,0);*
* delay(500);*
