Arduino W5500 + RFID not working
Hi Forum,
i am struggling with my setup.
I want to connect my RFID module (Sunfounder RFID-RC522) to my Arduino (DFRobot W5500) Leonardo compatible.
I connected it the following way:
ARDUINO RC522
3.3V VCC
PIN 9 NSS
ICSP1 (MISO) MISO
ICSP2 (VCC) (not connected)
ICSP3(SCK) SCK
ICSP4(MOSI) MOSI
ICSP5(RST) RST
ICSP6(GND) GND
I tried this Sketch:
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN		9		//
#define SS_PIN		10		//
MFRC522 mfrc522(SS_PIN, RST_PIN);	// Create MFRC522 instance
	Serial.begin(9600);		// Initialize serial communications with the PC
	while (!Serial);		// Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
	SPI.begin();			// Init SPI bus
	mfrc522.PCD_Init();		// Init MFRC522
	ShowReaderDetails();	// Show details of PCD - MFRC522 Card Reader details
	Serial.println(F("Scan PICC to see UID, type, and data blocks..."));
	// Look for new cards
	if ( ! mfrc522.PICC_IsNewCardPresent()) {
		return;
	// Select one of the cards
	if ( ! mfrc522.PICC_ReadCardSerial()) {
		return;
	// Dump debug info about the card; PICC_HaltA() is automatically called
	mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
void ShowReaderDetails() {
	// Get the MFRC522 software version
	byte v = mfrc522.PCD_ReadRegister(mfrc522.VersionReg);
	Serial.print(F("MFRC522 Software Version: 0x"));
	Serial.print(v, HEX);
	if (v == 0x91)
		Serial.print(F(" = v1.0"));
	else if (v == 0x92)
		Serial.print(F(" = v2.0"));
		Serial.print(F(" (unknown)"));
	Serial.println("");
	// When 0x00 or 0xFF is returned, communication probably failed
	if ((v == 0x00) || (v == 0xFF)) {
		Serial.println(F("WARNING: Communication failure, is the MFRC522 properly connected?"));
But i only got this error:
MFRC522 Software Version: 0x0 (unknown)
Scan PICC to see UID, type, and data blocks…
Anybody who can help me?
regards
Daniel
Dannyboy2209:
PIN 9 NSS
Dannyboy2209:
Answer: No.
Question: Is the MFRC522 5v tolerant on the SPI lines?
Hi, thanks for your answer.
Can you please help me connecting the reader correctly?
And what do you mean by: Is the MFRC522 5v tolerant on the SPI lines?
Regards
Daniel
It means that the MFRC522 is a 3V3 system and yet the Arduino sends out 5V data signals. Will this damage the MFRC522?
The answer is yes it will.
So buy a new one.
Solution use logic level shifters between all Arduino outputs and MFRC522 inputs, a 510R and 1K potential divider will do it.
Just to amplify @Grumpy_Mike's post, have a search for "SPI Level Shifter" or "SPI Level Translator". When you fully understand that, then digital pins 8 and 9 for RST and SS look OK to me. Have a browse and do a little research then come back to the forum with the bits you don't understand.
+1 karma for clear question.
To be clear on what you need:-
ARDUINO RC522
3.3V VCC
PIN 9 Level shift needed NSS
ICSP1 (MISO) MISO
ICSP3(SCK) Level shift needed SCK
ICSP4(MOSI) Level shift needed MOSI
ICSP5(RST) Level shift needed RST
ICSP6(GND) GND
Hello
Thanks a lot for your answer.
What i do Not understand is why do i Need a Level-shifter?
The RFID is connected To The 3.3V Output.
So why will The Module be Damaged?
How do i have to connect The Level shifter to The arduino and The MFRC522?
Greetings
Daniel
Because the Arduino is sending 5V signals. As a general rule you should not exceed more than 0.6V above the supply voltage for a chip. A look at the data sheet for that chip confirms that rule applies in this case.
See replies #5 & #3.
