Arduino wakeup WDT interrupt
How do you go about setting a WDT interrupt that will wake up an arduino from power down?
Can find an example of setting an pin level/change interrupt to wake up an arduino.
Can find an example of setting a WDT timer so that it will reset the Arduino.
But no examples of setting up the WDT to trigger an interrupt.
I'd be surprised if you could.
To enable the watchdog timer to wake up an ATmega328 from POWER_SAVE sleep mode, I use the following initialization sequence. You will also need an empty interrupt routine to process the interrupt.
set_sleep_mode(SLEEP_MODE_PWR_SAVE);
 // clear various "reset" flags
 MCUSR = 0;
 // allow changes, disable reset
 WDTCSR = (1<<WDCE) | (1<<WDE);
 // set interrupt mode and an interval
 WDTCSR = (1<<WDIE) | (1<<WDP2) | (1<<WDP0); // set WDIE, and 1/2 second timeout
 wdt_reset(); // reset it
The main loop has this code:
		sleep_enable();
		cli(); //time critical steps follow
		MCUCR = (1<<BODS) | (1<<BODSE);	// turn on brown-out enable select
		MCUCR = (1<<BODS);        		//Brown out off. This must be done within 4 clock cycles of above
		sei();
		sleep_cpu();
jremington:
// clear various “reset” flags
MCUSR = 0;
  sleep_enable();
	sei();
	sleep_cpu();
Does this code also work for and ATmega1280?
I tried this code to put the mega to sleep and it works nicely - my loop() function stops running.
void CPowerManager::powerDown()
	for (uint8_t nI = 0; nI < m_nNumDevices; nI++)
		m_arrayDevices[nI]->turnOff();
	// Sleep mode is set here
	set_sleep_mode(SLEEP_MODE_PWR_DOWN);
	// Enables the sleep bit in the mcucr register so sleep is possible - just a safety pin
	sleep_enable();
	pinMode(m_nTimerWakeupPin, INPUT_PULLUP);
	attachInterrupt(digitalPinToInterrupt(m_nTimerWakeupPin), m_pTimerWakeupISR, CHANGE);
	pinMode(m_nManualWakeupPin, INPUT_PULLUP);
	attachInterrupt(digitalPinToInterrupt(m_nManualWakeupPin), m_pManualWakeupISR, CHANGE);
	// Here the device is actually put to sleep!!
	sleep_mode();
	// THE PROGRAM CONTINUES FROM HERE AFTER WAKING UP
	// First thing after waking from sleep:
	sleep_disable();
	detachInterrupt(digitalPinToInterrupt(m_nTimerWakeupPin));
	detachInterrupt(digitalPinToInterrupt(m_nManualWakeupPin));
	// WAKEUP CODE HERE
	if (m_eWakeupType == eAutoWakeup)
    debug.log(F("********** AUTO WAKEUP **********"));
	else if (m_eWakeupType == eManualWakeup)
    debug.log(F("********** MANUAL WAKEUP **********"));
			m_arrayDevices[nI]->turnOn();
But why doesn’t touching either pin 2 or 3 with GND wake the mega up?
It just remains inactive until I reset it.
If I were in your shoes, I would study the ATmega1280 data sheet.
