Arduino/Water Flow Sensor If Else NOT WORKING
Hi!
I'm kinda new and working on this code for our school project. We are controlling a solenoid valve via a relay, and we also would like to control it based on the readings from the water flow sensor. The if else is working in that when enough pressure is applied the valve shuts off. However after that it does not loop and turn back on. Please help!
/*-----( Declare Constants and Pin Numbers )-----*/
int FlowSensor = A2;
int Relay = 7;
/*-----( Declare objects )-----*/
void setup()   /****** SETUP: RUNS ONCE ******/
  pinMode(FlowSensor, INPUT);
  pinMode(Relay, OUTPUT);
  digitalWrite(Relay, LOW);
}//--(end setup )---
void loop()   /****** LOOP: RUNS CONSTANTLY ******/
  if(analogRead(FlowSensor)>10)
    digitalWrite(Relay,HIGH);
  digitalWrite(Relay,LOW);
You have Serial.begin() but no Serial.print() statements (to print what you read from the sensor). Why not?
So put in a serial print to see what value you are reading from your sensor. That will tell you what is wrong.
