Hi everyone !
I'm kind of new with Arduino and I need some help as I found nothing on the web.
Here's my problem : I have this water pump I want to use and control water flow with an Arduino Uno, directly connected to my laptop. I would prefer, if possible, not to use an external battery.
Does anyone knows how to do it ? What should I buy to be able to control the pump, how do I have to connect the components with the Arduino Uno and what kind of code should I write ?
What kind of code should you write? It really actually depends on what you want the pump to do... so if you want help with that you have to provide some details on that...
Thanks to everyone,
Of course I found a lot of projects online I was just wondering if it was possible to not use the external, but I think it's not, thanks for the links @J-M-L,
To answer to @anon57585045, I want to use Arduino to command pump debit directly from the laptop to regulate liquids percentage with two different pumps. I'll try some links I found on the net,
Thanks all again
Hi again everyone,
I've found this project to control my pump, I just replaced the 12V supply with 8x1.5V batteries. However, nothing it's happening when I launch the Arduino program; I would like to attach a picture of what I did but the forum is not allowing me to do that, the only thing changing from the link is the batteries instead of the supply, can anyone help me understand what might be wrong?
Thank you again
