I had an idea last night that I could use an arduino as an audio mixer, and instead of using analog potentiometers, I could use digital potentiometers and control them via the web.
Out of my mixer I need two outputs, one to go to the speakers and one to go to my headphones. But on the headphones, I want to be able to select which audio channels I want to listen to. Is there some sort of digital switch I could use to turn the audio channels on and off?
Just like there are digitally controlled potentiometer ICs, there's also multiplexing ICs that allow you to route one input to several outputs, or vice-versa; a couple of these would probably work, and people here have used them to multiplex multiple potentiometers and sensors into the arduino's analog i/o - so it should work for your needs, too.
