Arduino Web Password Login
have a good day project at school but i encountered a problem i can't add password to my home automation code can you help
asking for a password when entering a website
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 8, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
char header[500];
int bufferSize = 0;
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // listen for incoming clients
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if(bufferSize < 500) header[bufferSize++] = c;
        if (c == '\n' && currentLineIsBlank) {
          //parse headers
          //bWluaDp0ZXN0 = 'minh:test' (user:password) base64 encode
          Serial.println(header);
          // send a standard http response header
          if(strstr(header, "bWluaDp0ZXN0") != NULL) {
            client.println("Content-Type: text/html");
            client.println("Connection: close");  // the connection will be closed after completion of the response
            client.println();
            if(strstr(header, "GET / HTTP/1.1")) {
              client.println("<!DOCTYPE HTML>");
              client.println("<html>");
              client.println("ulu");
              client.println("</html>");
              client.println("some other page");
            // wrong user/pass
            client.println("HTTP/1.1 401 Unauthorized");
            //client.println("HTTP/1.1 401 Authorization Required");
            client.println("WWW-Authenticate: Basic realm=\"Secure\"");
            client.println();
            client.println("<html>Text to send if user hits Cancel button</html>"); // really need this for the popup!
          bufferSize = 0;
          StrClear(header, 500);
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
I solved the issue, the subject may close
Hi Ulubey76,
Would you mind posting the version of code that works, because it might help someone out who has the same problem as you did! :slight_smile:
Thanks,
Zeb
