Arduino WebServer example - Portforwarding through Netcomm Router - Help
Using a UNO & Ethernet board I have the WebServer example working well using the Internal IP address of 192.168.1.177 through to a browser. My setup is on a port of a NetComm NB6Plus4W on a ADSL line.
My end aim is to access the Arduino server from a remote client.
My ISP provides me only with a dynamic IP address so I'm trying to use NOIP.COM to monitor my occasionally (dynamically) changing public IP to a static IP.
This free Dynamic DNS service takes your Dynamic IP address and makes it act as though it is static by pointing a static hostname to it and checking every 5 minutes for changes to your IP address. If your IP address changes, the Dynamic Update Client updates your hostname with the current IP address. Which means you can run a arduino server remotely. Specifically this should allow me access to my router using a web address like http://mysubdomain.ddns.net.and then through a connected port to the Arduino Server.
When I enter http://mysubdomain.ddns.net it does connect me through to the Netcomm login page.
Next step is to then try Port Forwarding from the WWW using typically a public IP of say 58.178.xxx.yyy but it won't work.
There is an excellent tutorial here on how to do this How to Port Forward ANY port. NetComm NB6 router. - YouTube this example follows the directions in the NetComm manual.
As I said before my local browser can connect to WebServer using the Internal IP address of 192.168.1.177.
Also I can also use the NOIP server to the server using http://mysubdomain.ddns.net & that connects to the NwetComm Router login page so that part works.
Problem is Port Forwarding through the router.
When I run PortCheckTool.com & ask it to test port 177 it reports that it times out waiting to see the port.
Has anyone been able to establish Portforwarding through a NetComm router to an arduino?
It isn't port 177. Check port 80. That is the "http" port.
Look in your manual on page 68 under "Virtual Server- Port Forwarding".
http://media.netcomm.com.au/public/assets/pdf_file/0015/40218/NB6Plus4W_REV2_UG.pdf
When I run PortCheckTool.com and specify port 80 I get following:
Success! I can see your service on 58.179.222.125 on port (80) Your ISP/Router/Firewall is not blocking port 80.
But I'm trying to get through to a port I specified e.g. 104 as specified in following example:
// next identify hardware
byte mac[] = { 0x48, 0xC2, 0xA1, 0xF3, 0x8D, 0xB7 };
byte ip[] = { 192,168,1, 104 }; // this is the address you type into browser & tell it to start the server on port 80
// keep in mind 192.168.1.1 will be the router - Start the server on port 80
// in format 192.168.1.104:80 on browser address line as port 80 is for http web requests
As in the comments to the code extract above I can use format 192.168.1.104:80 on browser address line and it does get through to the arduino on my local network but this is not a public IP address that I could use from anywhere in the world.
Appreciate any further help / comments
The "104" is not the port. It is the last octet of the IP address. The port is still 80 as I highlighted above.
If you change the IP, you must change the port forward address in the router to that IP.
