Hi everyone,
I am very new to Arduino and I am currently trying to code a webserver using the websocket protocol, such that my Arduino Uno R3 with Ethernet Shield 2 will read the number of pulses coming from a Hall sensor flowmeter (https://uk.rs-online.com/web/p/flow-sensors/5082704/) and will then briefly store that data, such that it could be accessed by a python program, and have this value output every second to a .csv file.
Currently, my arduino code can successfully output the number of pulses coming from the flowmeter using Serial.print(), and the arduino can be successfully pinged from a laptop, but currently, the client does not correctly output this data to a .csv file, despite no errors being produced.
This python code follows a previous example I have used before to interface with other pieces of scientific equipment, so I think the error maybe with the arduino code.
Below is the arduino code
#include <SPI.h>
#include <Ethernet.h>
int Pulses = 3; //Arduino digital pin 2 is declared as Pulses
volatile int pulsecount; //Variable to count number of pulses
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {0xA8, 0x61, 0x0A, 0xAE, 0x69, 0x13};
IPAddress ip(198, 162, 1, 177);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
//Interrupt pin 3 declared as input and pull up resitor is enabled
pinMode(Pulses, INPUT);
//Interrupt is attached to pin 3
//ISR(interuupt service routine) of interrupt is CountPulses
//Interrupt is activated on HIGH to LOW transition
attachInterrupt(digitalPinToInterrupt(Pulses), CountPulses, FALLING);
Serial.begin(9600); //Starting serial monitor
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Ethernet WebServer Example");
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// start the server
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
pulsecount = 0; //Start counting from 0 again
interrupts(); //Enables interrupt on arduino pin 3
delay (2000); //Wait 2 seconds
noInterrupts(); //Disable the interrupt
//One second is over now and we have the number of pulses in variable
//'pulsecount'
//Calculating the water flow rate in Milli Liters per minute (NEED TO CHANGE)
float flowRate;
flowRate = ((pulsecount) / (1420.0)); //flow rate in mL/s
Serial.print("Flow Rate [mL/s] =");
Serial.print(flowRate); //Print milli liters per second on serial monitor
void CountPulses()
pulsecount++; //Increment the variable on every pulse
For the sake of completeness, here is the python code too:
#!/usr/bin/python3
import asyncio
import websockets
import socket
import time
import datetime
starttime = time.time() # start value for timed data acquisition
# setup socket 1
s1 = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s1.connect(("198.162.1.177",80))
if True:
print('Connected')
def acquire():
data = s1.recv(2048)
dataline_tmc1 = datetime.datetime.today().isoformat() + "," + str(data) + "," + str(0) + "\n" # format and assemble data line
file_name_tmc1 = '{:%Y%m%d}'.format(datetime.datetime.today()) + "_flow-test.csv" # generate file name
with open(file_name_tmc1, "a") as tmc_file1: # append dataline to file
tmc_file1.write(dataline_tmc1)
while True:
acquire()
time.sleep(1.0 - ((time.time() - starttime) % 2.0)) # continue every (2.0 seconds)
s1.close()
Does anyone have any suggestions? Am I missing something simple regarding how I can send the value flowRate to the python client?
Thanks in advance
