Arduino webserver maximum urls supported
I am using arduino ethernet shield and I am running a sketch that needs about 17 urls to work as I want.(actually I use 4 sensors and I want them to refresh and do a couple of things more).To achieve that I use the command webserver.addcommand() but it seems that the arduino cannot support more than some urls (maybe 8 ).Does anybody have a clue about it or what should I do to make it work my way?
thanks
Yes. Fix your code. If you need help, hiding it isn't the way...
xoxoxoxo PaulS I found what was the problem.In the Webserver.h library the command m_commands[8]; has given by default 8 commands only.I changed to the number I wanted and now I can have as many urls as I want !
