arduino webserver php related...
Hey dear friends , i have code that read switch state and display on webpage. generally webpage store in SD card of Ethernet shield. bellow is my code but now i move to another area , same principle i wanna use but instead of SD card web page store in Xampp of local computer.what are changes in this code please suggest.Thanks !
arduino code:
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ   50
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 0, 20); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
File webFile;               // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
    // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(9600);       // for debugging
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    pinMode(7, INPUT);        // switch is attached to Arduino pin 7
    pinMode(8, INPUT);        // switch is attached to Arduino pin 8
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                // buffer first part of HTTP request in HTTP_req array (string)
                // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (StrContains(HTTP_req, "ajax_inputs")) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        // send XML file containing input states
                        XML_response(client);
                    else {  // web page request
                        client.println("Content-Type: text/html");
                        client.println();
                        // send web page
                        webFile = SD.open("index.htm");        // open web page file
                        if (webFile) {
                            while(webFile.available()) {
                                client.write(webFile.read()); // send web page to client
                            webFile.close();
                    // display received HTTP request on serial port
                    Serial.print(HTTP_req);
                    // reset buffer index and all buffer elements to 0
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
// send the XML file with switch statuses and analog value
void XML_response(EthernetClient cl)
    int analog_val;
    cl.print("<?xml version = \"1.0\" ?>");
    cl.print("<inputs>");
    cl.print("<button1>");
    if (digitalRead(7)) {
        cl.print("ON");
    else {
        cl.print("OFF");
    cl.print("</button1>");
    cl.print("<button2>");
    if (digitalRead(8)) {
        cl.print("ON");
    else {
        cl.print("OFF");
    cl.print("</button2>");
    // read analog pin A2
    analog_val = analogRead(2);
    cl.print("<analog1>");
    cl.print(analog_val);
    cl.print("</analog1>");
    cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
SD Card webpage :
<!DOCTYPE html>
<html>
    <head>
        <title>Arduino SD Card Web Page using Ajax with XML</title>
        <script>
        function GetArduinoInputs()
            nocache = "&nocache=" + Math.random() * 1000000;
            var request = new XMLHttpRequest();
            request.onreadystatechange = function()
                if (this.readyState == 4) {
                    if (this.status == 200) {
                        if (this.responseXML != null) {
                            // extract XML data from XML file (containing switch states and analog value)
                            document.getElementById("input1").innerHTML =
                                this.responseXML.getElementsByTagName('button1')[0].childNodes[0].nodeValue;
                            document.getElementById("input2").innerHTML =
                                this.responseXML.getElementsByTagName('button2')[0].childNodes[0].nodeValue;
                            document.getElementById("input3").innerHTML =
                                this.responseXML.getElementsByTagName('analog1')[0].childNodes[0].nodeValue;
            request.open("GET", "ajax_inputs" + nocache, true);
            request.send(null);
            setTimeout('GetArduinoInputs()', 1000);
    </script>
    </head>
    <body onload="GetArduinoInputs()">
        <h1>Arduino Inputs from SD Card Web Page using Ajax with XML</h1>
        <p>Button 1 (pin 7): <span id="input1">...</span></p>
        <p>Button 2 (pin 8): <span id="input2">...</span></p>
        <p>Analog (A2): <span id="input3">...</span></p>
    </body>
</html>
