Arduino WIFI and CAN-BUS library memory usage
Hi!
Im going to start a arduino project and want to know how much Memory WIFI and CAN bus library uses.
I ask becouse I'm going to log temperature and pressure and send it over wi-fi and CAN-BUS.
I also want to communicate over WIFI and CAN-BUS to activate a LED lamp.
Is arduino UNO good for this kind of project or do i need more memmory to have both CAN-BUS and wifi.
I have an Arduino UNO driving a Dragino LoRa wireless Shield and a Canbus Sheild
data received from canbus is transmitted via Lora to The Things Network
Note the both shields use pin 10 - I had to change the canbus shiled to use pin 3 as SPI CS (chip Select) pin
