I don't fully understand your setup BUT if you want to use your HardWare UART (RX/TX pins on Arduino) you cannot use them for USB communication at the same time.
Thanks for your reply; here's what I want to do in details:
I reflashed a Fonera with DD-WRT to set it up as a Wifi Client. It works; when I connect the Fonera to my computer through ethernet I'm able to surf the web. The Fonera also has an embedded serial port.
For my project, I want the fonera to send data to the serial port of the Fonera to send commands to upload data on the internet.
I have a USB Arduino board.
So to test, I want to sort of simulate the program I'll embed in the Arduino. I connected to Fonera to the RX/TX + GND of the Arduino and I connected my Mac to the USB of the Arduino.
What I expect:
Get on my Mac (through the Arduino SDK, or screen) the output of the Fonera and a login prompt.
Send data with the keyboard of my Mac to the Fonera through the Arduino.
If it doesn't work, do you have any idea? I should use "other" input/outputs? In such a case do you have a program to send data from the USB to the "other" RX and get data from the "other" TX sent to the USB?
Thanks, yes I've read that article; this where I discovered the Fonera :-o) The speed of the Fonera might be changed to 9600. I don't know how the guy tested his solution...
When you talk about SW serial port, you speak about the SoftwareSerial Library? The speed for this lib is 9600 bds.
yes, I talk about the SoftwareSerial lib (or its evolutions)
My suggestion - but it's just an idea - would be to use the HW uart for the fonera connection, and the SW uart for PC side communication, with a TTL-USB adapter (like FTDI's cables with embedded FT232)
