Dear All
I have successfully connected HC 04 Bluetooth module with my ARDUINO Uno using Rx Tx
Can use same method to connect WiFi module
Please advice
Thanks in advance
Dear All
Please advice
Thanks in advance
Not at the same time. (There's only one uart on the uno)
And not while uploading a sketch (same as now)
What WiFi module?
DrAzzy:
And not while uploading a sketch (same as now)What WiFi module?
Dear DrAzzy
Thanks for the reply
I am using one at a time
I have WiFi unit LoLin
Please see the link for WiFi unit that I am using
That link leads to search results that aren't specific to one board - is that an ESP8266-based board like NodeMCU?
ESP8266 works, definitely (though as noted, you must disconnect it while uploading sketches). Note that the NodeMCU boards have NodeMCU firmware loaded by default, not the AT-command firmware that is normally used when using the ESP8266 as a wifi adapter for another microcontroller.
DrAzzy:
Yes I think this is NodeMCU clone. It has Rx Tx pin and I connected it to Uno Rx Tx Correctly and run the following program
pinMode(13,OUTPUT);
byte value = Serial.read();
Serial.println(value);
Serial monitor is showing numbers
do you know good android app to connect to the wifi Module
Can you please advice how pair WiFi module and android app
WiFi is not "paired" to an application. You might write an android application that communicates by connecting to it, of course - but it's totally different from how you pair with bluetooth. I mean consider what bluetooth is used for (connectingf wireless mice, headsets, to a device, often a mobile something), while WiFi is used for internet access.
Wifi gives it internet access, so it can act as HTTP server, HTTP client, or (with more work) do more advanced things, but it doesn't "pair".
What do you want it to do?
The steps to take depend on that. Also, on whether you plan to use the AT firmware on the nodemcu board (which is appropriate for many ESP8266 libraries) or put your own code and leave the nodemcu firmware in place.
I have never use the nodemcu firmware. I normally run the AT firmware or Espruino (so I can program in JS - I spent a lot of time programming LUA a few years back, and I have no desire to repeat that). ESP8266 can even be programmed directly with Arduino, using the right core. I haven't done that though - I don't really enjoy writing internet-connected stuff in C because I'm a wimp.
DrAzzy:
Dear DrAzzy Thanks for detailed reply
Currently I am controlling my robot ( Car robot ) using Bluetooth ( HC 04 ) module
Example :- Car Turn left / Turn Right / Forward / Reverse
So I need do it same using WiFi Module with WiFi Andriod App
Please advice
Thanks in advance
arduino uno originals, messeger Could not find USBtiny device (0x2a03/0x49), help
