Arduino Wifi Rev2, bug when reading duty cycle value on pin 6
I am trying to read the duty cycle set for pin 6 on the Arduino Wifi Rev2. By default, the timer used is TCB0, used in 8-bit PWM mode. The 16-bit Compare channel CCMP is used as two 8-bit registers, the lowest byte CCMPL is for the period, while the highest byte CCMPH is for the duty cycle.
However, something weird happens when I try to read the Compare channel register, the value of CCMPH is unexpecteadly copied into CCMPL.
// PWM on pin 6, timer TCB0
//TCB_t* timer_B0 = (TCB_t *)&TCB0; // pointer on timer structure
  pinMode(6, OUTPUT);
  setPWMValueOnPin6(20);
  setPWMValueOnPin6(40);
  setPWMValueOnPin6(60);
  setPWMValueOnPin6(80);
void printCompareChannelValues()
  Serial.print("Compare channel = ");
  unsigned int r = TCB0_CCMP;
  //byte r = timer_B0->CCMP;
  Serial.println(r);
  Serial.print("Compare channel L = ");
  byte l = TCB0_CCMPL;
  //byte l = timer_B0->CCMPL;
  Serial.println(l);
  Serial.print("Compare channel H = ");
  byte h = TCB0_CCMPH;
  //byte h = timer_B0->CCMPH;
  Serial.println(h);
void setPWMValueOnPin6(byte value)
  analogWrite(6, value);
  printCompareChannelValues();
  delay(2000);
Here is the serial monitor output:
Compare channel = 5375
Compare channel L = 255
Compare channel H = 20
Compare channel = 10260
Compare channel L = 20
Compare channel H = 40
Compare channel = 15400
Compare channel L = 40
Compare channel H = 60
Compare channel = 20540
Compare channel L = 60
Compare channel H = 80
Compare channel = 5200
Compare channel L = 80
Problem occurs even when removing the serial functions (by watching at a led intensity on pin 6).
The same behavior occurs on pin 3 (timer TCB1).
Do you guys have any idea what is going on? Thanks for your help.
