I have a problem with the official arduino wifi shield and UNO all in R3.
When i begin SD operation, i cannot use Wifi. Here is the sketch :
WiFi Web Server LED Blink
#include <SPI.h>
#include <WiFi.h>
#include <SD.h>
File root;
char ssid[] = "dlink"; // your network SSID (name)
char pass[] = "xxxx"; // your network password
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
const int chipSelect = 4;
Serial.begin(9600); // initialize serial communication
pinMode(13, OUTPUT); // set the LED pin mode
Serial.print("\nInitializing SD card...");
// pinMode(53, OUTPUT); // change this to 53 on a mega
pinMode(10, OUTPUT);
if (!SD.begin(chipSelect)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
root = SD.open("/");
printDirectory(root, 0);
Serial.println("done!");
digitalWrite(4,HIGH); // forcage SS SD pour désactiver SD
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while (true); // don't continue
String fv = WiFi.firmwareVersion();
if ( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid); // print the network name (SSID);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
server.begin(); // start the web server on port 80
printWifiStatus(); // you're connected now, so print out the status
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("Click <a href=\"/H\">here</a> turn the LED on pin 9 on
client.print("Click <a href=\"/L\">here</a> turn the LED on pin 9 off
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check to see if the client request was "GET /H" or "GET /L":
if (currentLine.endsWith("GET /H")) {
digitalWrite(13, HIGH); // GET /H turns the LED on
if (currentLine.endsWith("GET /L")) {
digitalWrite(13, LOW); // GET /L turns the LED off
// close the connection:
client.stop();
Serial.println("client disonnected");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
// print where to go in a browser:
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void printDirectory(File dir, int numTabs) {
while (true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
for (uint8_t i = 0; i < numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
if (entry.isDirectory()) {
Serial.println("/");
printDirectory(entry, numTabs + 1);
// files have sizes, directories do not
Serial.print("\t\t");
Serial.println(entry.size(), DEC);
entry.close();
and the monitor says:
Initializing SD card…initialization done.
TI-01-06.CSV 26277
2015TELE.CSV 110
TI-01-07.CSV 61222
TI-01-10.CSV 61454
TI-01-11.CSV 61246
TI-01-12.CSV 61877
TI-01-13.CSV 24391
TI-01-08.CSV 61241
TI-01-09.CSV 61571
SYSTEM~1/
INDEXE~1 76
2015TELE.CS1 185
INDEX.HTM 13337
done!
Attempting to connect to Network named: dlink
If i comment the line “if (!SD.begin(chipSelect)) {” to " Serial.println(“done!”);", the Wifi works well.
The shield is updates at V 1.1.0
Can any help me, making a webserver with this bug are not cool…
