Arduino wifi shield Eifi v1.2 setup issue
I am having the wifi shield Eifi v1.2.
I have connected to the Arduino board and run the setup program.
I am not able to connect it.
I have refered to the url “http://www.elecfreaks.com/wiki/index.php?title=Wifi_Shield_-_EiFi
I have used the following code for setup.
** Description: **
** This file is a Wifi shield - EiFi set to TCP Server sample code **
** which base on Wizfi210 . Just for your reference. **
** Software Serialport Mode - Arduino will patch a serial link **
** between the computer and the Wifi Shield at 9600 bps 8-N-1 **
** Computer is connected to Hardware UART **
** Wifi Shield is connected to the Software UART **
** Copyright (C) 2011 ElecFreaks Corp. **
** Created by ElecFreaks Robi.W /17th Jeb 2012 **
** http://www.elecfreaks.com **
#include <SoftwareSerial.h>
#include <TimerOne.h>
#define rxPin 2
#define txPin 3
SoftwareSerial mySerial(rxPin, txPin);
int flag;
void Callback()
switch(flag)
// This command sets WPA Passphrase as “elecfreaks”
case 0: Serial.print(“AT+WWPA=40500244\r\n”);
mySerial.print(“AT+WWPA=40500244\r\n”);
// This command sets WizFi210 as using fixed IP address (not DHCP). When the IP address is acquired by DHCP…
case 1: Serial.print(“AT+NDHCP=0\r\n”);
mySerial.print(“AT+NDHCP=0\r\n”);
//This command sets the module with IP address (192.168.0.119), Subnet Mast (255.255.255.0), and Gateway Address (192.168.0.1).
case 2: Serial.print(“AT+NSET=192.168.0.119, 255.255.255.0, 192.168.0.1\r\n”);
mySerial.print(“AT+NSET=192.168.0.119, 255.255.255.0, 192.168.0.1\r\n”);
// This command sets WizFi210 with Server(1), TCP(1) and Port number (4000).
case 3: Serial.print(“AT+NAUTO=1,1,4000\r\n”);
mySerial.print(“AT+NAUTO=1,1,4000\r\n”);
// This command sets the AP’s Mode (0:Infrastructure), SSID(“dlink”), BSSID(Default)
case 4: Serial.print(“AT+WAUTO=0,biranchi@unifi\r\n”);
mySerial.print(“AT+WAUTO=0,biranchi@unifi\r\n”);
// This command initializes auto connection.
case 5: Serial.print(“ATA\r\n”);
mySerial.print(“ATA\r\n”);
flag++;
default: break;
// define pin modes for tx, rx pins:
flag = 0; // init flag
pinMode(rxPin, INPUT);
pinMode(txPin, OUTPUT);
mySerial.begin(9600); // setting baud to 9600
Serial.println(“Wifi Start …”);
Timer1.initialize(1000000); // setting callback is 1s
Timer1.attachInterrupt(Callback);
int i = 0;
char someChar[128] = {0};
// when characters arrive over the serial port…
if(Serial.available()) {
do{
someChar[i++] = Serial.read();
delay(3);
}while (Serial.available() > 0);
Serial.println(someChar);
mySerial.println(someChar);
char someChar2[128] = {0};
while(mySerial.available()) {
do{
someChar2[i++] = mySerial.read();
delay(3);
}while (mySerial.available() > 0);
if( strstr(someChar2, “OK”))
Serial.print(“OK\r\n”);
flag++;
Serial.print(someChar2);
Wifi Start …
AT+WWPA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
AT+WWPA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
+��PA=40500244
Please suggest me how can i fix it.
Thanks
