Arduino Wifi Shield POST Request
Hello I want to do a POST request with the “retired” Arduino Wifi Shield but i have an error message " connection failed" and I already update the firmware. So I need your help for send data with the BME280 sensor by WiFi
#include <SparkFunBME280.h>
#include <Wire.h>
#include <SPI.h>
#include <WiFi.h>
BME280 capteur;
byte mac[] = { 0x90, 0xA2, 0xDA, 0x10, 0x47, 0xF2 };
char ssid[] = "Bbox-676B70D";      //  your network SSID (name)
char pass[] = "F26A51FFE1CEF4DD2FFD4E651D31E2";   // your network password
int status = WL_IDLE_STATUS;
// Initialize the Wifi client library
WiFiClient client;
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
int interval = 15000;
String data="";
// server address:
IPAddress ip_server(192,168,1,66);
  //Initialize serial and wait for port to open:
  while (!Serial) {
  capteur.settings.commInterface = I2C_MODE;
  capteur.settings.I2CAddress = 0x76;
  capteur.settings.runMode = 3;
  capteur.settings.tStandby = 0;
  capteur.settings.filter = 0;
  capteur.settings.tempOverSample = 1 ;
  capteur.settings.pressOverSample = 1;
  capteur.settings.humidOverSample = 1; // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while (true);
  String fv = WiFi.firmwareVersion();
  if (fv != "1.1.0") {
    Serial.println("Please upgrade the firmware");
  delay(10);
  capteur.begin();
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    // Connect to WPA/WPA2 network. Change this line if using open or WEP network:
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  // you're connected now, so print out the status:
  printWifiStatus();
  currentMillis = millis();
if(currentMillis - previousMillis > interval)
    float t = capteur.readTempC();
    float p = capteur.readFloatPressure();
    data = "temp1=" + String(t)+ "&pres1=" + String(p);
    Serial.println(data);
    httpRequest();
void httpRequest() {
  // close any connection before send a new request.
  // This will free the socket on the WiFi shield
  client.stop();
  // if there's a successful connection:
  if (client.connect(ip_server,80)) {
    Serial.println("connecting...");
    // send the HTTP PUT request:
    client.println("POST /add2.php HTTP/1.1");
    client.print("Host: ");
    client.println(ip_server);
    client.println("User-Agent: ArduinoWiFi/1.1");
    client.println("Connection: close");
    client.print("Content-Length: ");
    client.println(data.length());
    client.println();
    client.println(data);
    // note the time that the connection was made:
    previousMillis = millis();
    // if you couldn't make a connection:
    Serial.println("connection failed");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
and what did you try to solve it?
