Hello everyone
I've tried this code and it prints "Couldn't get a wifi connection"
Could it be the WIFI shield or the Arduino Version ?
I'm using the 1.8.3
#include <WiFi.h>
char ssid[] = "IAP"; // your network SSID (name)
char pass[] = "12345678"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
// initialize serial:
// attempt to connect using WPA2 encryption:
Serial.println("Attempting to connect to WPA network...");
status = WiFi.begin(ssid, pass);
// if you're not connected, stop here:
if ( status != WL_CONNECTED) {
Serial.println("Couldn't get a wifi connection");
while(true);
// if you are connected, print out info about the connection:
else {
Serial.println("Connected to network");
// do nothing
MREG:
Although it's written on it "UNO & MEGA Compatible ?"
That just means that the shield connections are compatible with being plugged into an Uno or a Mega. The WiFi library does not support your shield. You will need to find and install a 3rd party library that supports cc3000 and then use one of the example sketches included with the library as a reference to verify everything is working.
