Hello there
I am trying to implement the following sketch to arduino WiFi uno
It freeze at line 40
if (WiFi.status() == WL_NO_WIFI_MODULE_COMM) {
any idea?
WiFi UDP Send and Receive String
This sketch wait an UDP packet on localPort using an Arduino board with WiFi Link.
When a packet is received an Acknowledge packet is sent to the client on port remotePort
Circuit:
- WiFi shield attached
created 30 December 2012
by dlf (Metodo2 srl)
modified 10 March 2017
by Sergio Tomasello and Andrea CannistrĂ¡
#include <WiFiLink.h>
#include <WiFiUdp.h>
int status = WL_IDLE_STATUS;
char ssid[] = "arduino"; // your network SSID (name)
char pass[] = "xxxxxxxxx"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
unsigned int localPort = 8888; // local port to listen on
char packetBuffer[255]; //buffer to hold incoming packet
char ReplyBuffer[] = "acknowledged"; // a string to send back
WiFiUDP Udp;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
//Check if communication with wifi module has been established
Serial.println("Hello There 1");
Serial.println("Communication with WiFi module not established.");
while (true); // don't continue:
// attempt to connect to Wifi network:
Serial.println("Hello There 2");
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid,pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
Udp.begin(localPort);
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize)
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remoteIp = Udp.remoteIP();
Serial.print(remoteIp);
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
int len = Udp.read(packetBuffer, 255);
if (len > 0) packetBuffer[len] = 0;
Serial.println("Contents:");
Serial.println(packetBuffer);
// send a reply, to the IP address and port that sent us the packet we received
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(ReplyBuffer);
Udp.endPacket();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
