Arduino WiFi Webserver Crashing??????
Hello,
I'm using an Arduino uno witha Wifi shield to create a webserver that will allow you to turn off LEDS over the internet. Everything works until you hit the submit button and then it crashes, loses it's connection and restarts?? Can someone please help me with this? Below is my code. Thanks for any help with this, it has become a major headache trying to debug.
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "";      //  your network SSID (name)
char pass[] = "";   // your network password
int keyIndex = 0;                 // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(1025);
String HTTP_req;          // stores the HTTP request
boolean LED_status = 0;   // state of LED, off by default
int numPins = 5;
int pins [] = {3, 4, 5, 6, 7};
int pinState[] = {0, 0, 0, 0, 0};
char line1[100];
  for (int i = 0; i < numPins; i++)
      pinMode(pins[i], OUTPUT);
  // start serial port:
  // attempt to connect to Wifi network:
  while ( status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    // wait 10 seconds for connection:
    delay(10000);
  server.begin();
  // you're connected now, so print out the status:
  void loop ()
    WiFiClient client = server.available();
    if (client)
      while (client.connected())
        readHeader(client);
        if (! pageNameIs("/"))
          client.stop();
          return;
        client.println("Content-Type: text/html");
        client.println();
        // send the body
        client.println("<html><body>");
        client.println("<Center>");
        client.println("<div style='background: #FF8000'>");
        client.println("<div style='border: solid 4px #660000'><p><u><h1>Remote LED Control</p></u></h1>");
        client.println("<form method= 'GET'>");
        setValuesFromParams();
        setPinStates();
          writeHTMLforPin(client, i);
        client.println("<input type='submit' value='Submit'/>");
        client.println("</form>");
        client.println("</body></html>");
        client.println("</div>");
        client.stop();
  void writeHTMLforPin(WiFiClient client, int i)
        client.println("<CENTER>");
        client.println("<p><font color='#0404B4'>LED</font>");
        client.print(pins[i]);
        client.print("<select name='");
        client.print(i);
        client.println("'>");
        client.println("</CENTER>");
        client.print("<option value='0'");
        if (pinState[i] == 0)
          client.println("selected");
        client.println(">On</option>");
        client.print("<option value='1'");
        if (pinState[i] ==1
          client.print("selected");
        client.println(">Off</option>");
        client.println("<select></p>");
  void setPinStates()
      digitalWrite(pins[i], pinState[i]);
  void setValuesFromParams()
      pinState[i] = valueOfParam(i + '0');
  void readHeader(WiFiClient client)
    // read first line of header
    char ch;
    int i = 0;
    while (ch != '\n')
      if (client.available())
        ch = client.read();
        line1 [i] = ch;
        i ++;
    line1[i] = '\0';
    Serial.println(line1);
  boolean pageNameIs(char* name)
    // page name starts at char  pos 4
    // ends with space
    int i = 4;
    char ch = line1[i];
    while (ch != ' ' && ch != '\n' && ch != '?')
      if (name[i-4] != line1[i])
        return false;
      i++;
      ch = line1[i];
    return true;
  int valueOfParam(char param)
    for (int i = 0; i < strlen(line1); i++)
      if (line1[i] == param && line1[i+1] == '=')
        return (line1[i+2] - '0');
    return 0;
There were two stickies at the top of the forum that you failed to read. Come on back after you have read them.
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
How to use this forum
Read this before posting a programming question
