Arduino+WiFly+Xively
I'm doing my final project and i have a trouble! When I send a datapoint from Arduino to xively and then i read the datastream the value is correct, but when i write the datapoint directly in Xively and then i do datastream[0].getFloat(), the value always is 0. I tried with an old version of Arduino IDE, changing the variables but nothing. I need help!!
My sketch is:
#include <SPI.h>
#include <WiFly.h>
#include <HttpClient.h>
#include <Xively.h>
#include <Sensirion.h>
char ssid[] = "......."; // Network SSID
char passphrase[] = "......."; // Contraseña red WiFi
// XivelyKey para que me lo cargue en mi feed
char xivelyKey[] = "...................................................";
// Define the string for our datastream ID
char temperatureId[] = "Ordenes";
XivelyDatastream datastreams[] = {
XivelyDatastream(temperatureId, strlen(temperatureId), DATASTREAM_FLOAT),
// Finally, wrap the datastreams into a feed
XivelyFeed feed(................, datastreams, 1 /* number of datastreams */);
WiFlyClient client;
XivelyClient xivelyclient(client);
//Inicialización del puerto serie y conexión a WiFi
Serial.println("Starting multiple datastream upload to Xively...");
// Bucle de conexión a la red WiFi
delay(100);
Serial.println("[Wifly]");
WiFly.begin();
Serial.println("finished beginning");
while(!WiFly.join(ssid, passphrase)){
WiFly.join(ssid, passphrase);
Serial.println("Association failed.");
delay(10000);
Serial.println("Connected to wifi");
// int ret = xivelyclient.get(feed, xivelyKey);
// Serial.print("xivelyclient.get returned ");
// Serial.println(ret);
// if (ret > 0)
Serial.println("Datastream is...");
Serial.println(feed[0]);
Serial.print("Temperature is: ");
Serial.println(feed[0].getFloat());
float float_value = datastreams[0].getFloat();
Serial.println(float_value, DEC);
Serial.println(datastreams[0]);
delay(15000UL);
And the message in Monitor Serial is :
Datastream is...
{ "id" : "Ordenes", "current_value" : "0.00" }
Temperature is: 0.00
0.0000000000
In Xively the current value is: 45
You have so much stuff commented out of the program, it doesn’t look like it does anything. You’re missing a put, and you’re reading out the wrong thing. Also, I would throw away the WiFly stuff until I got the xively stuff working correctly. One thing at a time.
I would also look at the code example here, in Chapter 12 - see attached. Note, this example has 3 data variables in the feed.
http://www.dummies.com/store/product/Arduino-Projects-For-Dummies.productCd-1118551478,navId-322496,descCd-DOWNLOAD.html
// send the supplied value to Xively, printing some debug information as we go
void sendData(int streamIndexNumber, float sensorValue) {
  datastreams[streamIndexNumber].setFloat(sensorValue);
  Serial.print("Sensor value is: ");
  Serial.println(datastreams[streamIndexNumber].getFloat());
  Serial.println("Uploading to Xively");
  int ret = xivelyclient.put(feed, API_KEY);
  //Serial.print("PUT return code: ");
  //Serial.println(ret);
// get the value of the datastream from Xively, printing out the values we received
void getData(int stream) {
  Serial.println("Reading the data back from Xively");
  int request = xivelyclient.get(feed, API_KEY);
  //Serial.print("GET return code: ");
  //Serial.println(request);
  if (request > 0) {
    Serial.print("Datastream: ");
    Serial.println(feed[stream]);
    Serial.print("Sensor value: ");
    Serial.println(feed[stream].getFloat());
    Serial.println("========================");
EDIT: you’ll also get more attention if you post this sort of thing to the Networking section.
APFD_Chapter12_Home_Sensing_Station.ino (4.65 KB)
There's a special case with WiFly ,Please see the problem I'm facing >> WiFly Xively Library errors - SparkFun Electronics
