Arduino Wireless Controller
i need some help connecting my Wireless Controller with my Arduino Uno.
i want to controle a quadcopter with that device. i am almost finished, done the hardest parts, controlling the motors, stabilization and so on.
The last thing is to connect my SL-4446-BK wireless controller with the Arduino.
the receiver of the controller is a usb device, i opened it and saw that inside it, there is a wifi receiver as far as i can see:
i didnt found any datasheet for kc-RF24DT-A1.
What do you think, is it to hard to try encripting the wifi signals?
What would you recommend?
Buying an USB or Wifi Shield is the easiest way, but i want first of all to understand it, therefore i made my own esc Controllers and after it worked well , i buyed better and smaller ones.
My main Objective is to understand how wifi connection works and how its realized?
Greetings,
Bunower
If you are cross-posting, you could have told us that you are also asking the question in the German section, Arduino Wifi Controller - Deutsch - Arduino Forum
It uses 2.4GHz.
I think it is not wifi and not Bluetooth, but rather an own protocol. Like other manufacturers (like Logitech) of mice and keyboards use 2.4GHz with an own protocol.
Detecting the protocol could be done with SDR (Software Defined Radio). However, most normal receiver don't receive up to 2.4GHz.
Making the protocol work with the Arduino could be a task that takes months. If you can't find code that someone already has made, you might try something else, like an other controller, or add an Arduino inside the controller.
Nice pictures. The real heart of that transmitter is under the two impenetrable drops of black epoxy. Most 2.4Ghz peripherals like this are either running Bluetooth or more likely in this case their own proprietary frequency hopping craziness. If its Bluetooth you might be able to talk to it, but if it does it's own thing it could be extremely hard. There is even a decent likelihood that matching the frequency hopping would basically require cryptography cracking too and that doesn't even get into the data encoding.
Compared with making one's own ESCs this could be orders of magnitude harder. The electronics are much more complicated, much faster clock speed, and you just don't have access to all of the information you would want.
http://www.emc.com.tw/twn/ap07_01_01_02_gp.asp
http://www.emc.com.tw/twn/com_prod_dsc.asp?gid=&tid=000001&tt=com_rfmod_ds&nn=2.4GHz+RF+Module
datasheet link is broken , drop a line to OEM.
jroorda:
Thank you very much.
i just tried to find the Controller via bluetooth, but it doesnt work.
sonnyyu:
i am scanning the website now, hoping to find more informations and i send a mail to the OEM. Just waiting for their answer
