Hello,
I'm trying to create a code to control 10 LEDs with 10 reed switches. I've found a sample code at https://dronebotworkshop.com/shift-registers/ where code is very close to what I'd like to accomplish. But I'd like to make some changes to fit my idea.
- Right now the LED only lights up when the button is pressed. I'd prefer if it stayed on until another button is pressed.
- When example calls for pull up resistors on buttons. Would it be possible to use Arduino Uno boards build in resistors to make the wiring simpler?
Any tips or directions would be appreciated as I'm having problems wrapping my mind around shift registers.
74HC595 & 74HC165 Shift Register Demonstration
74hc595-to-74ch165.ino
Input for 8 pushbuttons using 74HC165
Output to 0 LEDs using 74HC595
DroneBot Workshop 2020
// Define Connections to 74HC165
// PL pin 1
int load = 7;
// CE pin 15
int clockEnablePin = 4;
// Q7 pin 7
int dataIn = 5;
// CP pin 2
int clockIn = 6;
// Define Connections to 74HC595
// ST_CP pin 12
const int latchPin = 10;
// SH_CP pin 11
const int clockPin = 11;
// DS pin 14
const int dataPin = 12;
void setup () {
// Setup Serial Monitor
// 74HC165 pins
pinMode(load, OUTPUT);
pinMode(clockEnablePin, OUTPUT);
pinMode(clockIn, OUTPUT);
pinMode(dataIn, INPUT);
// 74HC595 pins
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// Read Switches
// Write pulse to load pin
digitalWrite(load, LOW);
delayMicroseconds(5);
digitalWrite(load, HIGH);
// Get data from 74HC165
digitalWrite(clockIn, HIGH);
digitalWrite(clockEnablePin, LOW);
byte incoming = shiftIn(dataIn, clockIn, LSBFIRST);
digitalWrite(clockEnablePin, HIGH);
// Print to serial monitor
Serial.print("Pin States:\r\n");
Serial.println(incoming, BIN);
// Write to LEDs
// ST_CP LOW to keep LEDs from changing while reading serial data
digitalWrite(latchPin, LOW);
// Shift out the bits
shiftOut(dataPin, clockPin, LSBFIRST, incoming);
// ST_CP HIGH change LEDs
digitalWrite(latchPin, HIGH);
